Ordro HDV-D395 Back Case Replacement
    1. Ordro HDV-D395 Back Case Replacement, Back Case: step 1, image 1 of 2 Ordro HDV-D395 Back Case Replacement, Back Case: step 1, image 2 of 2
      • Pull the slider labeled open, on the bottom right, to unlock the battery.
      Ask FixBot
    2. Ordro HDV-D395 Back Case Replacement: step 2, image 1 of 1
      • Pull battery out of slot.
      Ask FixBot
    3. Ordro HDV-D395 Back Case Replacement: step 3, image 1 of 1
      • Unfold the screen from the side of the camera.
      Ask FixBot
    4. Ordro HDV-D395 Back Case Replacement: step 4, image 1 of 1
      • Twist the screen so that the screen is facing downward.
      Ask FixBot
    5. Ordro HDV-D395 Back Case Replacement: step 5, image 1 of 2 Ordro HDV-D395 Back Case Replacement: step 5, image 2 of 2
      • Unscrew the four screws on the side (length 2.9 mm) with a JIS #000 screwdriver.
      • Unscrew the three screws on the bottom (length 7.7 mm) with a JIS #000 screwdriver.
      Ask FixBot
    6. Ordro HDV-D395 Back Case Replacement: step 6, image 1 of 1
      • Pull apart the camera into two pieces by pulling the side with the screen away from the main body of the camera.
      Ask FixBot
    7. Ordro HDV-D395 Back Case Replacement: step 7, image 1 of 2 Ordro HDV-D395 Back Case Replacement: step 7, image 2 of 2
      • Unscrew the two screws (size 4.75 mm) with a PH #00 screwdriver.
      • Unscrew the screw (size 7.65 mm) with a PH #00 screwdriver.
      Ask FixBot
    8. Ordro HDV-D395 Back Case Replacement: step 8, image 1 of 1
      • Take the back case off by pulling it away from the main body.
      • Be careful not to tear the white strap that connects the back case to the main body.
      Ask FixBot
    9. Ordro HDV-D395 Back Case Replacement: step 9, image 1 of 1
      • Unscrew all four screws (length 4.13 mm) on the inside of the case with a PH #00 screwdriver.
      Ask FixBot
    10. Ordro HDV-D395 Back Case Replacement: step 10, image 1 of 1
      • Pull the board away from the back case.
      Ask FixBot
Mostafa Abdulaleem
181 Reputation
1 Guide authored
IUPUI, Team S1-G3, Baechle Fall 2018 Member of IUPUI, Team S1-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 605
