Up to 20% off select tools
Orbo Jr. Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
83
All Time:
913
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will walk you through replacing the camera on the Orbo Jr. The cable ribbon clip can be broken and may require a gentle touch.
    1. Orbo Jr. Camera Replacement, Battery: step 1, image 1 of 1
      • Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
      Ask FixBot
    2. Orbo Jr. Camera Replacement: step 2, image 1 of 3 Orbo Jr. Camera Replacement: step 2, image 2 of 3 Orbo Jr. Camera Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
      • Go slowly when you pry the back off to ensure you do not crack the case or damage the screen.
      Ask FixBot
    3. Orbo Jr. Camera Replacement: step 3, image 1 of 1
      • Gently pull the cables attached to the speaker to remove it from the back cover.
      • The speaker is taped in the back cover and caution should be used when pulling on the wires.
      Ask FixBot
    4. Orbo Jr. Camera Replacement: step 4, image 1 of 1
      • Pull back the tape to expose the wires that are attached to the battery.
      Ask FixBot
    5. Orbo Jr. Camera Replacement: step 5, image 1 of 2 Orbo Jr. Camera Replacement: step 5, image 2 of 2
      • Do not attempt to fully remove the battery. It is still connected to the motherboard by two wires.
      • Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
      • To avoid damage to device and battery, do not attempt to remove the battery until adhesive is completely detached.
      Ask FixBot
    6. Orbo Jr. Camera Replacement: step 6, image 1 of 3 Orbo Jr. Camera Replacement: step 6, image 2 of 3 Orbo Jr. Camera Replacement: step 6, image 3 of 3
      • Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
      • Positive and Negative battery terminals.
      • Be careful to not make contact to other components on the motherboard while using the soldering iron.
      Ask FixBot
    1. Orbo Jr. Camera Replacement, Camera: step 7, image 1 of 3 Orbo Jr. Camera Replacement, Camera: step 7, image 2 of 3 Orbo Jr. Camera Replacement, Camera: step 7, image 3 of 3
      • Use the pointed end of a spudger to flip up the black tab connecting the camera's ribbon cable to the motherboard.
      • Camera ribbon clip.
      • Pull lightly on the ribbon to remove the camera ribbon from the tab.
      Ask FixBot
Author
with
Ryan Christman
684 Reputation
5 Guides authored
USF Tampa, Team 3-1, Sullivan Spring 2016 Member of USF Tampa, Team 3-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 83
All Time: 913
