Tools
Introduction
Go to step 1 ↓This guide walks through the steps on how to remove the battery from the Orbo Jr so you can add a new battery.
Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
Positive and Negative battery terminals.
