Orbic Wonder Speaker Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
65
All Time:
973
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Orbic Wonder Speaker Replacement, Battery: step 1, image 1 of 3 Orbic Wonder Speaker Replacement, Battery: step 1, image 2 of 3 Orbic Wonder Speaker Replacement, Battery: step 1, image 3 of 3
      • Remove two 2mm TR9 Torx screws from the bottoms of the device.
      Ask FixBot
    2. Orbic Wonder Speaker Replacement: step 2, image 1 of 3 Orbic Wonder Speaker Replacement: step 2, image 2 of 3 Orbic Wonder Speaker Replacement: step 2, image 3 of 3
      • There is a border between the black phone backing and the silver screen.
      • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
      • When the halves are parted correctly, the gap should look like this.
      • Be careful to avoid damaging any connecting circuitry between the two halves.
      Ask FixBot
    3. Orbic Wonder Speaker Replacement: step 3, image 1 of 3 Orbic Wonder Speaker Replacement: step 3, image 2 of 3 Orbic Wonder Speaker Replacement: step 3, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
      • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
      Ask FixBot
    4. Orbic Wonder Speaker Replacement: step 4, image 1 of 3 Orbic Wonder Speaker Replacement: step 4, image 2 of 3 Orbic Wonder Speaker Replacement: step 4, image 3 of 3
      $3.99
      Buy
      • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
      • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
      Ask FixBot
    5. Orbic Wonder Speaker Replacement: step 5, image 1 of 3 Orbic Wonder Speaker Replacement: step 5, image 2 of 3 Orbic Wonder Speaker Replacement: step 5, image 3 of 3
      • There is a black flap on the bottom of the battery.
      • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
      Ask FixBot
    1. Orbic Wonder Speaker Replacement, Speaker: step 6, image 1 of 3 Orbic Wonder Speaker Replacement, Speaker: step 6, image 2 of 3 Orbic Wonder Speaker Replacement, Speaker: step 6, image 3 of 3
      $7.95
      Buy
      • Remove the anti-static wrist strap.
      • Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
      • Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
      Ask FixBot
    2. Orbic Wonder Speaker Replacement: step 7, image 1 of 2 Orbic Wonder Speaker Replacement: step 7, image 2 of 2
      $3.99
      Buy
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 65
All Time: 973
