Up to 20% off select tools
Orbic Wonder Screen Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
80
All Time:
4,445
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide covers the steps to remove and replace the broken screen on your Orbic wonder. Some steps are repeated, as this is a guide made up of other guides.
    1. Orbic Wonder Screen Replacement, Battery: step 1, image 1 of 3 Orbic Wonder Screen Replacement, Battery: step 1, image 2 of 3 Orbic Wonder Screen Replacement, Battery: step 1, image 3 of 3
      • Remove two 2mm TR9 Torx screws from the bottoms of the device.
      Ask FixBot
    2. Orbic Wonder Screen Replacement: step 2, image 1 of 3 Orbic Wonder Screen Replacement: step 2, image 2 of 3 Orbic Wonder Screen Replacement: step 2, image 3 of 3
      • There is a border between the black phone backing and the silver screen.
      • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
      • When the halves are parted correctly, the gap should look like this.
      • Be careful to avoid damaging any connecting circuitry between the two halves.
      Ask FixBot
    3. Orbic Wonder Screen Replacement: step 3, image 1 of 3 Orbic Wonder Screen Replacement: step 3, image 2 of 3 Orbic Wonder Screen Replacement: step 3, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
      • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
      Ask FixBot
    4. Orbic Wonder Screen Replacement: step 4, image 1 of 3 Orbic Wonder Screen Replacement: step 4, image 2 of 3 Orbic Wonder Screen Replacement: step 4, image 3 of 3
      $3.99
      Buy
      • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
      • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
      Ask FixBot
    5. Orbic Wonder Screen Replacement: step 5, image 1 of 3 Orbic Wonder Screen Replacement: step 5, image 2 of 3 Orbic Wonder Screen Replacement: step 5, image 3 of 3
      • There is a black flap on the bottom of the battery.
      • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
      Ask FixBot
    1. Orbic Wonder Screen Replacement, Speaker: step 6, image 1 of 3 Orbic Wonder Screen Replacement, Speaker: step 6, image 2 of 3 Orbic Wonder Screen Replacement, Speaker: step 6, image 3 of 3
      $7.95
      Buy
      • Remove the anti-static wrist strap.
      • Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
      • Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
      Ask FixBot
    2. Orbic Wonder Screen Replacement: step 7, image 1 of 2 Orbic Wonder Screen Replacement: step 7, image 2 of 2
      $3.99
      Buy
      Ask FixBot
    1. Orbic Wonder Screen Replacement, Charging Port Circuit Board: step 8, image 1 of 3 Orbic Wonder Screen Replacement, Charging Port Circuit Board: step 8, image 2 of 3 Orbic Wonder Screen Replacement, Charging Port Circuit Board: step 8, image 3 of 3
      $3.99
      Buy
      • Detach the metal casing at the bottom of the phone.
      • Unplug the cable connector.
      • Use a pair of angled tweezers to unplug the black wire.
      Ask FixBot
    2. Orbic Wonder Screen Replacement: step 9, image 1 of 3 Orbic Wonder Screen Replacement: step 9, image 2 of 3 Orbic Wonder Screen Replacement: step 9, image 3 of 3
      • Using a pair of angled tweezers, disconnect the connector chip.
      • With the angled tweezers, gently lift (but do not remove) the green circuit board from the phone.
      Ask FixBot
    3. Orbic Wonder Screen Replacement: step 10, image 1 of 2 Orbic Wonder Screen Replacement: step 10, image 2 of 2
      • Using a pair of angled tweezers, disconnect the attachment to the microphone labeled "JD," and completely remove the circuit board.
      Ask FixBot
    1. Orbic Wonder Screen Replacement, Screen: step 11, image 1 of 2 Orbic Wonder Screen Replacement, Screen: step 11, image 2 of 2
      • Remove the six 2mm Phillips #000 screws from the motherboard.
      Ask FixBot
    2. Orbic Wonder Screen Replacement: step 12, image 1 of 2 Orbic Wonder Screen Replacement: step 12, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the leftmost metal protector.
      • Repeat this process for the other metal protector directly above the battery.
      Ask FixBot
    3. Orbic Wonder Screen Replacement: step 13, image 1 of 3 Orbic Wonder Screen Replacement: step 13, image 2 of 3 Orbic Wonder Screen Replacement: step 13, image 3 of 3
      • Disconnect the "L" shaped plug connecting the battery to the circuit board.
      • Carefully disconnect the small gold connecting wire.
      • Disconnect the rectangular piece.
      • Each of these steps are very delicate. Use a pair of tweezers to avoid causing damage.
      Ask FixBot
    4. Orbic Wonder Screen Replacement: step 14, image 1 of 2 Orbic Wonder Screen Replacement: step 14, image 2 of 2
      • Unplug the power button connector.
      • Unplug the circuit connector above the battery.
      • These are very delicate and important connections. Be sure to use a pair of tweezers to avoid causing damage.
      Ask FixBot
    5. Orbic Wonder Screen Replacement: step 15, image 1 of 2 Orbic Wonder Screen Replacement: step 15, image 2 of 2
      • Carefully remove the protective sticker. This will expose the camera and its connector.
      Ask FixBot
    6. Orbic Wonder Screen Replacement: step 16, image 1 of 2 Orbic Wonder Screen Replacement: step 16, image 2 of 2
      • Disconnect the camera connector.
      Ask FixBot
    7. Orbic Wonder Screen Replacement: step 17, image 1 of 1
      • The circuit board should now be loose. Disconnect it, and remove it from the phone housing.
      Ask FixBot
    8. Orbic Wonder Screen Replacement: step 18, image 1 of 3 Orbic Wonder Screen Replacement: step 18, image 2 of 3 Orbic Wonder Screen Replacement: step 18, image 3 of 3
      • Using the iOpener, heat the screen's edges to loosen the adhesive holding the screen in place.
      • This will make the phone very warm. Gloves may be necessary depending on the level of heat required.
      • Using the Jimmy and opening picks, gently pry the screen from the phone housing.
      Ask FixBot
    9. Orbic Wonder Screen Replacement: step 19, image 1 of 2 Orbic Wonder Screen Replacement: step 19, image 2 of 2
      • Push the gold lower screen connector wire through the hole.
      • Do the same to the gold upper screen connector wire.
      Ask FixBot
    10. Orbic Wonder Screen Replacement: step 20, image 1 of 3 Orbic Wonder Screen Replacement: step 20, image 2 of 3 Orbic Wonder Screen Replacement: step 20, image 3 of 3
      • Using your hands, separate the screen from the rest of the phone, ensuring that the connector wires go through the openings without ripping.
      • The screen is completely detached from the rest of the phone.
      Ask FixBot
Author
with
Grant Adler
859 Reputation
5 Guides authored
3 Guide Comments
how can and or can I swap media files from orbic wonder “with damaged screen “ to a gaxalxy a01
Ron Harrell - Reply Share
My orbic was over amped.7 volts burned something out.it turns on but nothing works.and the screen is light grey.how do i repair this plz thank you. 209crazo
209 Crazo - Reply Share
I need orbic lcd
Gzn Khan - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 80
All Time: 4,445
