Up to 20% off select tools
Orbic Wonder Battery Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
103
All Time:
8,542
Comments: 3
3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide provides instruction to remove and replace a depleted battery in your Orbic Wonder. Before beginning, discharge your Orbic Wonder battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Turn off the Orbic Wonder prior to disassembly.
    1. Orbic Wonder Battery Replacement, Battery: step 1, image 1 of 3 Orbic Wonder Battery Replacement, Battery: step 1, image 2 of 3 Orbic Wonder Battery Replacement, Battery: step 1, image 3 of 3
      • Remove two 2mm TR9 Torx screws from the bottoms of the device.
      Ask FixBot
    2. Orbic Wonder Battery Replacement: step 2, image 1 of 3 Orbic Wonder Battery Replacement: step 2, image 2 of 3 Orbic Wonder Battery Replacement: step 2, image 3 of 3
      • There is a border between the black phone backing and the silver screen.
      • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
      • When the halves are parted correctly, the gap should look like this.
      • Be careful to avoid damaging any connecting circuitry between the two halves.
      Ask FixBot
    3. Orbic Wonder Battery Replacement: step 3, image 1 of 3 Orbic Wonder Battery Replacement: step 3, image 2 of 3 Orbic Wonder Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
      • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
      Ask FixBot
    4. Orbic Wonder Battery Replacement: step 4, image 1 of 3 Orbic Wonder Battery Replacement: step 4, image 2 of 3 Orbic Wonder Battery Replacement: step 4, image 3 of 3
      $3.99
      Buy
      • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
      • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
      Ask FixBot
    5. Orbic Wonder Battery Replacement: step 5, image 1 of 3 Orbic Wonder Battery Replacement: step 5, image 2 of 3 Orbic Wonder Battery Replacement: step 5, image 3 of 3
      • There is a black flap on the bottom of the battery.
      • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
      Ask FixBot
2 other people completed this guide.
Author
with
Grant Adler
859 Reputation
5 Guides authored
3 Guide Comments
where do you buy the replacement battery at ?
ricotoomo - Reply Share
Where can I buy a replacement battery
Robert Smith - Reply Share
Thank you big help your smart
gansterms123 - Reply Share
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 103
All Time: 8,542
