Oral-B iO Battery Replacement
Views: 610K
View statistics:
Past 24 Hours:
325
Past 7 Days:
2,491
Past 30 Days:
11,020
All Time:
610,285
Comments: 159
67 comments on steps, 92 guide comments.
Go to guide comments
Completed: 133
133 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Oral-B iO.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your toothbrush. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need the charging station of the Oral-B iO during the battery removal procedure.
Parts
Tools
    1. Oral-B iO Battery Replacement, Unfasten bottom cap: step 1, image 1 of 2 Oral-B iO Battery Replacement, Unfasten bottom cap: step 1, image 2 of 2
      • Before you start, disconnect the charging station from the power socket.
      • Flip the charging station of your Oral-B iO upside down.
      • Align the three recesses on the iO's silver bottom cap with the notches at the bottom of the charging station.
      • Push the toothbrush into the charging station with mild pressure and turn it about 90° counter clockwise to unlock the thread of the bottom cap.
      Ask FixBot
    2. Oral-B iO Battery Replacement, Bottom cap removal: step 2, image 1 of 1
      • Unscrew the bottom cap of your toothbrush.
      • Remove the bottom cap.
      Ask FixBot
    1. Oral-B iO Battery Replacement, Pry up the metal ring: step 3, image 1 of 2 Oral-B iO Battery Replacement, Pry up the metal ring: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • It is possible that toothpaste residues or lime have accumulated underneath the metal ring above the gray rubber gasket. For this reason, the ring may behave somewhat stubbornly during removal.
      • Insert one arm of a pair of tweezers or a small flathead screwdriver underneath the bottom edge of the metal ring sitting above the grey rubber gasket.
      • Use your tool to carefully pry up the metal ring.
      • The metal ring is held in place by small plastic clips. During reassembly make sure, it snaps back into place.
      • When prying up the metal ring be careful not to puncture or tear the grey rubber gasket.
      Ask FixBot
    2. Oral-B iO Battery Replacement, Remove the metal ring: step 4, image 1 of 2 Oral-B iO Battery Replacement, Remove the metal ring: step 4, image 2 of 2
      • Use a pair of tweezers or your finger to remove the metal ring.
      • This is a good point during reassembly to clean off toothpaste residues and lime from the gasket and the metal ring. However avoid using liquid cleaners or use them in very small amounts. With the removed metal ring they can run easily inside the toothbrush causing water damage.
      Ask FixBot
    3. Oral-B iO Battery Replacement, Remove toothbrush assembly: step 5, image 1 of 3 Oral-B iO Battery Replacement, Remove toothbrush assembly: step 5, image 2 of 3 Oral-B iO Battery Replacement, Remove toothbrush assembly: step 5, image 3 of 3
      • Remove the brush head from your toothbrush.
      • Hold the toothbrush body in one hand and use your thumb to press down the top of the toothbrush assembly.
      • Pull the toothbrush assembly out of the opening at the bottom end of the toothbrush body.
      Ask FixBot
    4. Oral-B iO Battery Replacement, Battery removal: step 6, image 1 of 2 Oral-B iO Battery Replacement, Battery removal: step 6, image 2 of 2
      • Do not use excessive force or pry at the battery with metal tools.
      • Pull the battery out of its recess on the bottom of the toothbrush assembly.
      • In case the battery sits to tight in its recess, you can use a plastic tool like a spudger to pry the battery out of its recess.
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      Ask FixBot
If possible, turn on your toothbrush and test your repair before resealing.
133 other people completed this guide.
Dominik Schnabelrauch
266,911 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,955 Guides authored
92 Guide Comments
thank you for this tutorial! any idea how to source a battery for it? Couldn’t find a 0307 740 mh type
M Marco - Reply Share
can you tell what is the size of battery (dimensions) ? it’s LiOn but what is the form factor of it?
marcinlag - Reply Share
14500 is the form factor. See comment below
John McEntee - Reply Share
Thank you for your tutorial, it allowed me to fix a dropped toothbrush
martin - Reply Share
My toothbrush got knocked over on the counter and it started doing this weird loop of booting but not going into the menu, and doing and doing it. Until it shows the battery is at 0%. Just ordered the battery and hopefully that was just the issue and that the knocking over was just coincidental. I opened it up and no parts just randomly fell out and checked the circuit board it and nothing looked like it got knocked out of place.
Albion Ong - Reply Share
Past 24 Hours: 325
Past 7 Days: 2,491
Past 30 Days: 11,020
All Time: 610,285
