Oral-B Vitality Power Button Replacement
    1. Oral-B Vitality Power Button Replacement, Power Button: step 1, image 1 of 3 Oral-B Vitality Power Button Replacement, Power Button: step 1, image 2 of 3 Oral-B Vitality Power Button Replacement, Power Button: step 1, image 3 of 3
      • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
      Ask FixBot
    2. Oral-B Vitality Power Button Replacement: step 2, image 1 of 1
      • Locate the 4 terminals connecting the power button to the circuit board.
      Ask FixBot
    3. Oral-B Vitality Power Button Replacement: step 3, image 1 of 3 Oral-B Vitality Power Button Replacement: step 3, image 2 of 3 Oral-B Vitality Power Button Replacement: step 3, image 3 of 3
      • Desolder the 4 terminals and remove the old button.
      • Remove as much of the old solder as possible.
      Ask FixBot
    4. Oral-B Vitality Power Button Replacement: step 4, image 1 of 1
      • Attach the new button by soldering the 4 terminals with new solder.
      Ask FixBot
8 other people completed this guide.
Grady Bennett
509 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Fall 2017 Member of IUPUI, Team S2-G1, Harley Fall 2017
IUPUI-HARLEY-F17S2G1
3 Members
36 Guides authored
5 Guide Comments
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - Reply Share
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - Reply Share
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - Reply Share
True except if the switch is permanently β€œon”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim - Reply Share
In my case the inside of the case of the toothbrush where the cover for the start button is, was worn. I cut 3 - 3/16" squares of electrical tape and placed it on top of the start switch. This filled the gap where the worn material was and enabled the switch to be activated easier. I also noticed that some moisture was inside the case of the toothbrush, so I coated the metal shaft protruding from the toothbrush, and the o ring of the cap with some water proof grease, Vaseline.
Robert Carl - Reply Share
Past 24 Hours: 7
Past 7 Days: 49
Past 30 Days: 213
All Time: 14,165
