Up to 20% off select tools
Optoma PRO360W Bulb Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
116
All Time:
1,604
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide will provide a step-by-step process on how to safely remove and replace a light bulb for an Optoma PRO360W projector. In the process of this removal, we will demonstrate how to clean the area of any dust and how to recycle the waste material- the old light bulb.
    1. Optoma PRO360W Bulb Replacement, Unplug projector: step 1, image 1 of 1
      • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
      Ask FixBot
    2. Optoma PRO360W Bulb Replacement: step 2, image 1 of 1
      • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
      Ask FixBot
    3. Optoma PRO360W Bulb Replacement: step 3, image 1 of 1
      • Unscrew the bulb screws on either side of the silver plate.
      Ask FixBot
    4. Optoma PRO360W Bulb Replacement: step 4, image 1 of 1
      • Remove the light bulb from the projector by lifting the silver handle and pulling up.
      Ask FixBot
    5. Optoma PRO360W Bulb Replacement: step 5, image 1 of 1
      • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
      Ask FixBot
    6. Optoma PRO360W Bulb Replacement: step 6, image 1 of 1
      • Use a new Q-tip to clean the fan blades and hole in which the light enters.
      Ask FixBot
    7. Optoma PRO360W Bulb Replacement: step 7, image 1 of 1
      • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
      Ask FixBot
    8. Optoma PRO360W Bulb Replacement: step 8, image 1 of 1
      • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
      Ask FixBot
    9. Optoma PRO360W Bulb Replacement: step 9, image 1 of 1
      • Dispose of the bulb by sending it to a recycling center.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Desiree Benitez
128 Reputation
1 Guide authored
1 Guide Comment
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 116
All Time: 1,604
