Up to 20% off select tools
Optoma HD72 Projection Lamp Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
73
All Time:
534
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the Projection Lamp on the Optoma HD72. A projection lamp is a very powerful bulb used to project images or a video. The projection lamp will need to be replaced if you are experiencing any of the following symptoms.
  • Projection Lamp’s light is becoming dim
  • The Lamp has burnt out completely
  • A connection has become loose
A warning when replacing the bulb is to be wary of any electrostatic charge. Be sure to wear proper PPE i.e. rubber gloves, as well as ensure the device has been turned off for at least 5-10 minutes before disassembling.
    1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: step 1, image 1 of 1
      • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
      • Remove the panel.
      Ask FixBot
    2. Optoma HD72 Projection Lamp Replacement: step 2, image 1 of 1
      • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
      Ask FixBot
    3. Optoma HD72 Projection Lamp Replacement: step 3, image 1 of 2 Optoma HD72 Projection Lamp Replacement: step 3, image 2 of 2
      • Lift the panel off of the device using the metal handle.
      • Disconnect the pink wires from the black plastic housing.
      Ask FixBot
    4. Optoma HD72 Projection Lamp Replacement: step 4, image 1 of 3 Optoma HD72 Projection Lamp Replacement: step 4, image 2 of 3 Optoma HD72 Projection Lamp Replacement: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
      • Remove the projection lamp casing by gently lifting the bulb from its housing.
      Ask FixBot
    5. Optoma HD72 Projection Lamp Replacement: step 5, image 1 of 2 Optoma HD72 Projection Lamp Replacement: step 5, image 2 of 2
      • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
      • The second photo is what the completed bulb housing should look like.
      Ask FixBot
Author
with
Oscar Garcia
677 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 73
All Time: 534
