Optoma HD72 Power Supply Replacement
    1. Optoma HD72 Power Supply Replacement, Upper Case: step 1, image 1 of 2 Optoma HD72 Power Supply Replacement, Upper Case: step 1, image 2 of 2
      • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
      Ask FixBot
    2. Optoma HD72 Power Supply Replacement: step 2, image 1 of 1
      • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
      • Disconnect the two cables that connect the top case to the motherboard.
      • Lift the upper case up and off.
      Ask FixBot
    1. Optoma HD72 Power Supply Replacement, Power Supply: step 3, image 1 of 3 Optoma HD72 Power Supply Replacement, Power Supply: step 3, image 2 of 3 Optoma HD72 Power Supply Replacement, Power Supply: step 3, image 3 of 3
      • Remove the four 2 mm Phillips screws that secure the motherboard.
      • Remove the detachable wire bundles that connect to the ballast supply.
      Ask FixBot
    2. Optoma HD72 Power Supply Replacement: step 4, image 1 of 3 Optoma HD72 Power Supply Replacement: step 4, image 2 of 3 Optoma HD72 Power Supply Replacement: step 4, image 3 of 3
      • Remove the four 2 mm Phillips #2 screws that secure the power supply.
      • Remove the 2 2.0mm Phillips #2 screws that secure the ballast to the power supply using a Phillips #2 screwdriver
      • Disconnect all of the ballast connections.
      • Lift the ballast out of the device.
      Ask FixBot
    3. Optoma HD72 Power Supply Replacement: step 5, image 1 of 3 Optoma HD72 Power Supply Replacement: step 5, image 2 of 3 Optoma HD72 Power Supply Replacement: step 5, image 3 of 3
      • Remove the two Phillips screws that secure the power supply.
      • Disconnect the ballast from the power supply.
      • Remove the power supply.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 28
All Time: 319
