Up to 20% off select tools
Optoma HD20 Light Bulb Replacement
Views: 13K
View statistics:
Past 24 Hours:
6
Past 7 Days:
32
Past 30 Days:
150
All Time:
13,287
Comments: 5
5 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the light bulb from your Optoma HD20.
    1. Optoma HD20 Light Bulb Replacement, Rear Panel: step 1, image 1 of 2 Optoma HD20 Light Bulb Replacement, Rear Panel: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
      Ask FixBot
    2. Optoma HD20 Light Bulb Replacement: step 2, image 1 of 1
      • Lift the panel off of the device.
      Ask FixBot
    3. Optoma HD20 Light Bulb Replacement, Light Bulb Casing: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
      • The screws don't come out all the way.
      Ask FixBot
    4. Optoma HD20 Light Bulb Replacement: step 4, image 1 of 3 Optoma HD20 Light Bulb Replacement: step 4, image 2 of 3 Optoma HD20 Light Bulb Replacement: step 4, image 3 of 3
      • Remove the light bulb casing from the device.
      • Steps 5-9 are unnecessary if the replacement light bulb comes with housing.
      Ask FixBot
    5. Optoma HD20 Light Bulb Replacement, Light Bulb: step 5, image 1 of 1
      • Remove the three 4.5 mm screws on the light bulb case.
      Ask FixBot
    6. Optoma HD20 Light Bulb Replacement: step 6, image 1 of 1
      • Carefully remove the light bulb insulator from the light bulb casing.
      Ask FixBot
    7. Optoma HD20 Light Bulb Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Gently pull the wires off of the pins using tweezers.
      Ask FixBot
    8. Optoma HD20 Light Bulb Replacement: step 8, image 1 of 1
      • Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
      Ask FixBot
    9. Optoma HD20 Light Bulb Replacement: step 9, image 1 of 2 Optoma HD20 Light Bulb Replacement: step 9, image 2 of 2
      • Remove the casing, then gently pull out the old light bulb and replace it with the new one.
      Ask FixBot
7 other people completed this guide.
Author
with
Trever
1,303 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
72 Guides authored
5 Guide Comments
I recently replaced my bulb for the third time and the insulator had grown brittle I am guessing from the heat and it broke. I can't seem to find this part for sale anywhere. Does anyone know if is possible to purchase it?
Thomas - Reply Share
The screws in step 8 are extremely hard to get off. I went and bought proper screwdrivers before even attempting since theyre small, but in a day I've only managed to get one off and I'm having to resort to other tactics, even using a drill to just grind the heads off.
dv01_ - Reply Share
king@okinlamps.com
Need LAD60 20PCS
kingshen92 - Reply Share
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
Taringajohn - Reply Share
my hd 20 projects dull images i recently replaced my bulb for the first time successfully and i followed as per menu trying to bulb reset but it is not working and still image is dull how to solve the problem
kumar - Reply Share
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 150
All Time: 13,287
