Up to 20% off select tools
Optoma HD20 Focal Lens Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
95
All Time:
5,178
Comments: 9
9 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the focal lens from your Optoma HD20.
    1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: step 1, image 1 of 2 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: step 1, image 2 of 2
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      Ask FixBot
    2. Optoma HD20 Focal Lens Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      Ask FixBot
    3. Optoma HD20 Focal Lens Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      Ask FixBot
    4. Optoma HD20 Focal Lens Replacement: step 4, image 1 of 1
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      Ask FixBot
    1. Optoma HD20 Focal Lens Replacement, Focal Lens: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
      Ask FixBot
    2. Optoma HD20 Focal Lens Replacement: step 6, image 1 of 1
      • Remove the focal lens by twisting it clockwise until it comes off.
      Ask FixBot
Author
with
Trever
1,303 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 95
All Time: 5,178
