Up to 20% off select tools
Optoma HD20 Fan Replacement
Views: 15K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
142
All Time:
14,908
Comments: 23
17 comments on steps, 6 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the fan from your Optoma HD20.
    1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: step 1, image 1 of 2 Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: step 1, image 2 of 2
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      Ask FixBot
    2. Optoma HD20 Fan Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      Ask FixBot
    3. Optoma HD20 Fan Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      Ask FixBot
    4. Optoma HD20 Fan Replacement: step 4, image 1 of 1
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      Ask FixBot
    1. Optoma HD20 Fan Replacement, Fan: step 5, image 1 of 1
      • Peel off the tape that is holding the metal casing down.
      Ask FixBot
    2. Optoma HD20 Fan Replacement: step 6, image 1 of 2 Optoma HD20 Fan Replacement: step 6, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
      • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
      Ask FixBot
    3. Optoma HD20 Fan Replacement: step 7, image 1 of 1
      • Remove the metal casing by lifting it up off of the circuit board.
      Ask FixBot
    4. Optoma HD20 Fan Replacement: step 8, image 1 of 1
      • Unplug the six wires stemming from the circuit board.
      Ask FixBot
    5. Optoma HD20 Fan Replacement: step 9, image 1 of 1
      • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
      Ask FixBot
    6. Optoma HD20 Fan Replacement: step 10, image 1 of 1
      • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
      Ask FixBot
    7. Optoma HD20 Fan Replacement: step 11, image 1 of 1
      • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
      Ask FixBot
    8. Optoma HD20 Fan Replacement: step 12, image 1 of 1
      • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
      • Lift the plastic backing to remove it.
      Ask FixBot
    9. Optoma HD20 Fan Replacement: step 13, image 1 of 1
      • Ensure all screws are removed
      • Lift up the motherboard and take out the metal container beneath it.
      • Do this very carefully as there is still one cable attached.
      Ask FixBot
    10. Optoma HD20 Fan Replacement: step 14, image 1 of 1
      • Unplug the white connector underneath the right side of the circuit board.
      • To remove, pinch both sides of the connector and pull it away from the circuit board.
      Ask FixBot
    11. Optoma HD20 Fan Replacement: step 15, image 1 of 2 Optoma HD20 Fan Replacement: step 15, image 2 of 2
      • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
      Ask FixBot
    12. Optoma HD20 Fan Replacement: step 16, image 1 of 2 Optoma HD20 Fan Replacement: step 16, image 2 of 2
      • Pull the fan away from the metal housing unit.
      • Gently lift the fan up and out of the device. The fan is now removed.
      Ask FixBot
6 other people completed this guide.
Author
with
Trever
1,303 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
72 Guides authored
6 Guide Comments
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - Reply Share
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - Reply Share
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague - Reply Share
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - Reply Share
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 142
All Time: 14,908
