Up to 20% off select tools
Optoma HD20 Color Wheel Replacement
Views: 10K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
144
All Time:
10,383
Comments: 12
9 comments on steps, 3 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the color wheel from your Optoma HD20.
    1. Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: step 1, image 1 of 2 Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: step 1, image 2 of 2
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      Ask FixBot
    2. Optoma HD20 Color Wheel Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      Ask FixBot
    3. Optoma HD20 Color Wheel Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      Ask FixBot
    4. Optoma HD20 Color Wheel Replacement: step 4, image 1 of 1
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      Ask FixBot
    1. Optoma HD20 Color Wheel Replacement, Color Wheel: step 5, image 1 of 1
      • Use the plastic opening tool to remove the wiring.
      Ask FixBot
    2. Optoma HD20 Color Wheel Replacement: step 6, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
      Ask FixBot
    3. Optoma HD20 Color Wheel Replacement: step 7, image 1 of 1
      • Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
      Ask FixBot
    4. Optoma HD20 Color Wheel Replacement: step 8, image 1 of 1
      • Using a flat head screw driver unscrew the back part to release the color wheel.
      • Do this carefully because these screws do not pull out.
      Ask FixBot
    5. Optoma HD20 Color Wheel Replacement: step 9, image 1 of 1
      • Once unscrewed, remove the color wheel, and replace the part.
      Ask FixBot
7 other people completed this guide.
Author
with
Trever
1,303 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
72 Guides authored
3 Guide Comments
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
srbaucom - Reply Share
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter - Reply Share
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 144
All Time: 10,383
