Up to 20% off select tools
Optoma HD20 Air Filter Replacement
Views: 14K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
115
All Time:
14,036
Comments: 12
11 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the air filter from your Optoma HD20.
    1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: step 1, image 1 of 2 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: step 1, image 2 of 2
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      Ask FixBot
    2. Optoma HD20 Air Filter Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      Ask FixBot
    3. Optoma HD20 Air Filter Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      Ask FixBot
    4. Optoma HD20 Air Filter Replacement: step 4, image 1 of 1
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      Ask FixBot
    1. Optoma HD20 Air Filter Replacement, Air Filter: step 5, image 1 of 3 Optoma HD20 Air Filter Replacement, Air Filter: step 5, image 2 of 3 Optoma HD20 Air Filter Replacement, Air Filter: step 5, image 3 of 3
      • Carefully peel off each air filter from the device
      • Pull up on the air filter to remove it.
      Ask FixBot
    2. Optoma HD20 Air Filter Replacement: step 6, image 1 of 1
      • Remove the air filter from the device.
      • Try not to deposit dirt from the air filter into the inside of the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Trever
1,303 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
72 Guides authored
1 Guide Comment
There were no filters where the photos indicate.
Michael - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 115
All Time: 14,036
