Oppo X9000 Rear Camera Replacement
    1. Oppo X9000 Rear Camera Replacement, Removing the Back Cover: step 1, image 1 of 2 Oppo X9000 Rear Camera Replacement, Removing the Back Cover: step 1, image 2 of 2
      • Turn the phone over so that you are facing the back side of the phone.
      • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
      • Completely remove the back cover by moving down the sides and bottom with your fingers.
      Ask FixBot
    2. Oppo X9000 Rear Camera Replacement, Removing the Battery: step 2, image 1 of 1
      • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
      Ask FixBot
    1. Oppo X9000 Rear Camera Replacement, Remove the Back Panel Screws: step 3, image 1 of 2 Oppo X9000 Rear Camera Replacement, Remove the Back Panel Screws: step 3, image 2 of 2
      • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
      • Store all the screws in a safe place where you will not lose them.
      Ask FixBot
    2. Oppo X9000 Rear Camera Replacement, Remove the Rubber Stoppers: step 4, image 1 of 2 Oppo X9000 Rear Camera Replacement, Remove the Rubber Stoppers: step 4, image 2 of 2
      • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
      Ask FixBot
    3. Oppo X9000 Rear Camera Replacement, Remove the Newly Exposed Screws: step 5, image 1 of 1
      • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
      Ask FixBot
    4. Oppo X9000 Rear Camera Replacement, Lift off the Back Panel: step 6, image 1 of 2 Oppo X9000 Rear Camera Replacement, Lift off the Back Panel: step 6, image 2 of 2
      • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
      Ask FixBot
    1. Oppo X9000 Rear Camera Replacement, Rear Camera: step 7, image 1 of 2 Oppo X9000 Rear Camera Replacement, Rear Camera: step 7, image 2 of 2
      • Use your fingers to pull the camera straight up from the motherboard to fully detach the camera.
      Ask FixBot
5 other people completed this guide.
Sara Dafoe
375 Reputation
2 Guides authored
Cal Poly, Team 4-45, Amido Fall 2014 Member of Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Members
120 Guides authored
1 Guide Comment
Hi,
Do you know where I could find a Oppo X9000 rear camera for a replacement ? Mine is broken and send it to Oppo is too expensive...
Thanks.
Jonathann Kjetsa - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 102
All Time: 2,650
