Up to 20% off select tools
Oppo X9000 Power Button Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
93
All Time:
4,495
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is for replacing the power button, not the electric switches.
    1. Oppo X9000 Power Button Replacement, Removing the Back Cover: step 1, image 1 of 2 Oppo X9000 Power Button Replacement, Removing the Back Cover: step 1, image 2 of 2
      • Turn the phone over so that you are facing the back side of the phone.
      • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
      • Completely remove the back cover by moving down the sides and bottom with your fingers.
      Ask FixBot
    2. Oppo X9000 Power Button Replacement, Removing the Battery: step 2, image 1 of 1
      • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
      Ask FixBot
    1. Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: step 3, image 1 of 2 Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: step 3, image 2 of 2
      • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
      • Store all the screws in a safe place where you will not lose them.
      Ask FixBot
    2. Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: step 4, image 1 of 2 Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: step 4, image 2 of 2
      • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
      Ask FixBot
    3. Oppo X9000 Power Button Replacement, Remove the Newly Exposed Screws: step 5, image 1 of 1
      • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
      Ask FixBot
    4. Oppo X9000 Power Button Replacement, Lift off the Back Panel: step 6, image 1 of 2 Oppo X9000 Power Button Replacement, Lift off the Back Panel: step 6, image 2 of 2
      • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
      Ask FixBot
    1. Oppo X9000 Power Button Replacement, Remove the Power Button Bracket: step 7, image 1 of 1
      • Use the sharp end of the spudger to pry the power button bracket from the side of the rear case.
      Ask FixBot
    2. Oppo X9000 Power Button Replacement, Let the Button Fall Out: step 8, image 1 of 1
      • Rotate the phone onto its side so that the power button falls out with ease.
      • Make sure not to lose the power button.
      Ask FixBot
4 other people completed this guide.
Author
with
Joe Hanacek
565 Reputation
2 Guides authored
Cal Poly, Team 4-45, Amido Fall 2014 Member of Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Members
120 Guides authored
1 Guide Comment
I am having trouble with my buttons as they no long spring back after i replaced the speaker. They now just sit flush with the body of the phone, both buttons and metal brackets are installed.
Any ideas?
Jake Karp - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 93
All Time: 4,495
