Up to 20% off select tools
Opening the case
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
124
All Time:
759
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Opening the case
Introduction
Go to step 1 ↓
One of my recharger pins inside the case got stuck. I found no instructions on how to open the case, so I took a risk and opened it with a fine small knife.
There are two hinges in the front where the case needs to be pushed out with the knife. There is no cable connection between the upper and the lower part of the case, so you don't have to take extra care for opening it.
I unscrewed the pin holder once it opened.
    1. Opening the case, Case: step 1, image 1 of 1
      • Mit dem Messer vorsichtig entlang der Naht schneiden. Dann beginnen, das Gehäuse mit dem Messer auseinander zu hebeln
      Ask FixBot
    2. Opening the case: step 2, image 1 of 1
      • Auch die Rückseite aufhebeln
      Ask FixBot
    3. Opening the case: step 3, image 1 of 1
      • Schrauben lösen und Pin Halterung entnehmen. Die Pins konnte ich so mit Alkohol reinigen und mit einer kleinen Zange in Bewegung bringen.
      Ask FixBot
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Author
with
huedrant
129 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 124
All Time: 759
