Opening the Withings ScanWatch (Gen 1)
Views: 5.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
45
Past 30 Days:
225
All Time:
5,402
Comments: 16
10 comments on steps, 6 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
There is not much information out there about opening the ScanWatch (1st generation), so I am sharing the notes I made after buying a unit that had already been repaired for water damage. After the first shower, condensation showed up again.
Here is what I found out, especially how to open the watch and close it back up.
Parts
Tools
    1. Opening the Withings ScanWatch (Gen 1), Open the Case: step 1, image 1 of 1
      • The watch is held together by friction and a thin black gasket. There are no screws or glue.
      • Place a thin metal smartphone opening tool between the metal case and the glass/display side of the watch, not on the sensor side.
      • Work your way around the watch carefully to release the gasket.
      Ask FixBot
    2. Opening the Withings ScanWatch (Gen 1), Disconnect the Sensor Cable: step 2, image 1 of 1
      • Once the watch is open, you can see the movement and a small cable connecting the sensor to it.
      • The cable has an iPhone-like connector and can be released with a plastic spudger.
      • Carefully pry the connector straight up to avoid damage.
      • Do not pull on the cable. Disconnect the connector first.
      Ask FixBot
    1. Opening the Withings ScanWatch (Gen 1), Open the Case: step 3, image 1 of 1
      Ask FixBot
    2. Opening the Withings ScanWatch (Gen 1), Disconnect the Sensor Cable: step 4, image 1 of 1
      Ask FixBot
      • The battery can be replaced, but it is soldered to the board.
      • You need soldering experience and the right tools.
      • This is not a beginner step and can damage the board.
      Ask FixBot
      • Reconnect the sensor cable.
      • Make sure the O-ring gasket sits fully in the corner of the metal ring.
      • Press the glass and ring back in with even pressure. This may take force.
      • Remove any adhesive residue and let the adhesive cure if you used any.
      • If the gasket does not sit properly, the watch will not close fully.
      Ask FixBot
Hopefully the photos and the steps help. Withings does not offer much more information or support, so this guide fills in some of the gaps.
Have you found a better way to handle this repair? Share your experience in the comments so we can keep building our repair knowledge together.
2 other people completed this guide.
Cäsh
7 Reputation
2 Guides authored
6 Guide Comments
Hi,
Thanks for teardown and information!
Please let me know where to buy battery from?
Albert Einstein - Reply Share
It seems like these are the battery suppliers. Battery. Sadly you can’t cheaply buy from them…
Cäsh - Reply Share
Where can I find the saphire glass if its broken?
krunal modi - Reply Share
Also looking for a battery: where could I find it? model seems to be "FLPB302828R"
dvd - Reply Share
What about if the back cover comes loose? Mine is completely loose.
MikeA - Reply Share
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 225
All Time: 5,402
