Opening the Samsung Galaxy Watch Active
  1. Opening the Samsung Galaxy Watch Active, Turn off the watch: step 1, image 1 of 2 Opening the Samsung Galaxy Watch Active, Turn off the watch: step 1, image 2 of 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    Ask FixBot
  2. Opening the Samsung Galaxy Watch Active, Remove the rear screws: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    Ask FixBot
  3. Opening the Samsung Galaxy Watch Active, Separate the back cover from the housing: step 3, image 1 of 3 Opening the Samsung Galaxy Watch Active, Separate the back cover from the housing: step 3, image 2 of 3 Opening the Samsung Galaxy Watch Active, Separate the back cover from the housing: step 3, image 3 of 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    Ask FixBot
  4. Opening the Samsung Galaxy Watch Active, Disconnect the sensor array: step 4, image 1 of 2 Opening the Samsung Galaxy Watch Active, Disconnect the sensor array: step 4, image 2 of 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    Ask FixBot
  5. Opening the Samsung Galaxy Watch Active, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
    Ask FixBot
14 other people completed this guide.
Tobias Isakeit
133,983 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 57
Past 30 Days: 215
All Time: 26,192
