This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓The PowerBook Duo's power adapter (M7783) is prone to failing; after years of use, a capacitor inside it tends to explode when plugged in. To replace it, the power adapter must be opened. Unfortunately, these adapters are glued shut and have no way to be opened. With these instructions, however, it can still be opened.
Please note: Because some parts are glued together, it is not possible to take the device apart without leaving any visible marks. However, following these instructions should allow you to do so with minimal damage.
To open the housing, you need to pry open the adhesive joint. This can be done using a flat, thin tool, such as a chisel and a screw clamp, as shown here.
Gently tighten the screw clamp until you hear a soft click from the housing. Do not tighten it too much, or you may damage the electronics inside.
This is now repeated on all sides, twice on each long side.
Special thanks to these translators:
100%
Thomas Bucher is helping us fix the world! Want to contribute?
Start translating ›
