Up to 20% off select tools
Opening the Hood
Views: 90K
View statistics:
Past 24 Hours:
48
Past 7 Days:
319
Past 30 Days:
1,284
All Time:
89,791
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Very easy
Opening the Hood
Introduction
Go to step 1 ↓
Opening the hood is required to access the engine bay and perform many vehicle maintenance tasks.
    1. Opening the Hood, Opening the Hood: step 1, image 1 of 2 Opening the Hood, Opening the Hood: step 1, image 2 of 2
      • Locate the hood latch beside the driver's side door, next to the left foot rest.
      • Pull the latch toward you to release the hood.
      Ask FixBot
    2. Opening the Hood: step 2, image 1 of 2 Opening the Hood: step 2, image 2 of 2
      • Walk around to the front of the vehicle.
      • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
      • Once the tab is released, lift the hood up.
      Ask FixBot
    3. Opening the Hood: step 3, image 1 of 2 Opening the Hood: step 3, image 2 of 2
      • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
      • Place the tip of the hood stand into the hole located in the upper left of the hood.
      • You can now let the hood rest on the stand.
      Ask FixBot
6 other people completed this guide.
Author
with
Shaun MacDonald
2,669 Reputation
8 Guides authored
Cal Poly, Team 24-27, Regan Fall 2012 Member of Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Members
96 Guides authored
1 Guide Comment
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - Reply Share
Past 24 Hours: 48
Past 7 Days: 319
Past 30 Days: 1,284
All Time: 89,791
