This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Opening the Copal 222 Flip Clock
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
91
All Time:
245
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
For most repairs—such as replacing the neon light bulb—and for cleaning, you need to open the clock. This is shown here.
Tools
    1. Opening the Copal 222 Flip Clock, Copal 222 Flip Clock: step 1, image 1 of 2 Opening the Copal 222 Flip Clock, Copal 222 Flip Clock: step 1, image 2 of 2
      • Unplug the power cord!
      • The two screws on the bottom of the device primarily hold a weight at the bottom in place. They should not be completely unscrewed to open the housing!
      • For your information, the weight is shown in image 2. It is sufficient if it is loosened slightly.
      Ask FixBot
    2. Opening the Copal 222 Flip Clock: step 2, image 1 of 1
      • Pry the adjustment wheel on the right side off using a plastic opening tool.
      Ask FixBot
    3. Opening the Copal 222 Flip Clock: step 3, image 1 of 3 Opening the Copal 222 Flip Clock: step 3, image 2 of 3 Opening the Copal 222 Flip Clock: step 3, image 3 of 3
      • Insert opening picks into the gap between the rear case and the front panel. Release the four clips.
      • The clips are highlighted in red in image 2 for your reference.
      Ask FixBot
    4. Opening the Copal 222 Flip Clock: step 4, image 1 of 1
      • Pull the back housing with the clockwork off the front part toward the back.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
VauWeh
344,589 Reputation
317 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 91
All Time: 245
