Opening the Column in the Hamilton Galileo
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: step 1, image 1 of 1
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    Ask FixBot
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
    Ask FixBot
  2. Opening the Column in the Hamilton Galileo: step 3, image 1 of 1
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
    Ask FixBot
  3. Opening the Column in the Hamilton Galileo: step 4, image 1 of 2 Opening the Column in the Hamilton Galileo: step 4, image 2 of 2
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    Ask FixBot
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
    Ask FixBot
Ian Van Sciver
332 Reputation
2 Guides authored
Cal Poly, Team S7-G26, Paton Spring 2020 Member of Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 49
All Time: 340
