Up to 20% off select tools
Opening the Case
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
96
All Time:
1,584
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Opening the Case
Tools
    1. Opening the Case, Opening the Case: step 1, image 1 of 1
      • Tool on left - PH000 screwdriver
      • Tool on right - iPod fix-it tool
      • Soldering Iron
      Ask FixBot
    2. Opening the Case: step 2, image 1 of 1
      • Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
      Ask FixBot
    3. Opening the Case: step 3, image 1 of 2 Opening the Case: step 3, image 2 of 2
      • Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
      Ask FixBot
    4. Opening the Case: step 4, image 1 of 1
      • Use the iPod fix-it tool to separate the back panel from the camera.
      Ask FixBot
Author
with
Travis Buck
113 Reputation
2 Guides authored
Ohio State, Team 1-2, Buehl Fall 2012 Member of Ohio State, Team 1-2, Buehl Fall 2012
OSU-BUEHL-F12S1G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 96
All Time: 1,584
