This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Opening the Bosch MUM4
View statistics:
Past 24 Hours:
9
Past 7 Days:
42
Past 30 Days:
134
All Time:
840
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The MUM4 series is an older line of Bosch swivel arm models. In order to perform repairs, the swivel arm must usually be opened.
    1. Opening the Bosch MUM4, Opening the Bosch MUM4: step 1, image 1 of 3 Opening the Bosch MUM4, Opening the Bosch MUM4: step 1, image 2 of 3 Opening the Bosch MUM4, Opening the Bosch MUM4: step 1, image 3 of 3
      • Unplug the power cord!
      • Position the swivel arm so that you can lay it flat on the work surface with the underside facing up.
      • As a precaution, lay a cloth on the work surface.
      • Remove the five Torx T15 screws on the underside.
      • Carefully lift off the underside of the swivel arm. If it is stuck, use a plastic opening tool to help.
      • When reassembling, ensure that the power cable runs through the corresponding cutout.
      Ask FixBot
    2. Opening the Bosch MUM4: step 2, image 1 of 3 Opening the Bosch MUM4: step 2, image 2 of 3 Opening the Bosch MUM4: step 2, image 3 of 3
      • Mark the setting of the rotary selector and carefully lift it out.
      • Watch out for the white push rod that connects the rotary selector to the PCB. It is fragile and can easily fall out.
      • Inserting the push rod during reassembly is a bit tricky. It is easier if you lift the entire motor unit up slightly. Insert one pin of the push rod into the selector wheel first, then the second pin into the corresponding hole on the PCB.
      • The swivel arm is open and you can continue working on the motor or the drive.
      • Watch out for the other half of the cover on the swivel arm; it detaches easily, especially when you lift the device off the work surface.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
VauWeh
344,271 Reputation
317 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 42
Past 30 Days: 134
All Time: 840
