Up to 20% off select tools
Opening Tapco Link Series device
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
21
All Time:
521
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
How to open your Link.usb Audio Interface device despite no visible screws.
    1. Opening Tapco Link Series device, Introduction: step 1, image 1 of 1
      • Put the device in front of you, with the knob labels the right side up
      Ask FixBot
    2. Opening Tapco Link Series device, Revealing Screws: step 2, image 1 of 2 Opening Tapco Link Series device, Revealing Screws: step 2, image 2 of 2
      • Pry the rubber off the top of the device
      • All the rubber
      • Use your fingernails, then pull with your bare hands. Do no use a heat gun or prying tool as they will damage the adhesive.
      • 5 screw holes will appear. Leave them alone for now.
      Ask FixBot
    3. Opening Tapco Link Series device: step 3, image 1 of 2 Opening Tapco Link Series device: step 3, image 2 of 2
      • Look at the side of the device with the metal stand
      • Take a heat gun to the two small foam pads
      • You only need to pry off the halves on the top plastic shell
      • Put scraps of glossy paper on the foam pads to prevent them from sticking on again
      • Alternatively, if you do not mind sacrificing aesthetics, you may slice the foam pads down the middle as in the picture.
      Ask FixBot
    4. Opening Tapco Link Series device: step 4, image 1 of 2 Opening Tapco Link Series device: step 4, image 2 of 2
      • Now remove the 5 Philips screws on top
      Ask FixBot
    5. Opening Tapco Link Series device: step 5, image 1 of 1
      • Simply lift off the top
      • No clips anywhere
      Ask FixBot
    6. Opening Tapco Link Series device: step 6, image 1 of 1
      • You could now lift out the whole innards
      • They are not attached to the bottom shell
      • No, the mess of glue is how it left the factory
      Ask FixBot
Author
with
Tobias
10 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 521
