Up to 20% off select tools
Opening Procedure
Views: 2.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
108
All Time:
2,849
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Opening Procedure
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the back cover assembly on your TicWatch Pro 3 GPS.
You’ll need replacement adhesive to reattach the back cover assembly when reassembling the device. Your device will function normally, but will lose its IP (Ingress Protection) rating.
    1. Opening Procedure, Power down your watch: step 1, image 1 of 2 Opening Procedure, Power down your watch: step 1, image 2 of 2
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Ask FixBot
    2. Opening Procedure, Unfasten the back cover: step 2, image 1 of 1
      • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
      Ask FixBot
    3. Opening Procedure, Loosen the back cover adhesive: step 3, image 1 of 1
      • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    4. Opening Procedure, Pry up the back cover assembly: step 4, image 1 of 3 Opening Procedure, Pry up the back cover assembly: step 4, image 2 of 3 Opening Procedure, Pry up the back cover assembly: step 4, image 3 of 3
      • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
      • Pry upwards to loosen the back cover assembly. This may require some force.
      • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
      • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
      Ask FixBot
    5. Opening Procedure, Disconnect the sensor assembly cable: step 5, image 1 of 2 Opening Procedure, Disconnect the sensor assembly cable: step 5, image 2 of 2
      • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    6. Opening Procedure, Remove the back cover assembly: step 6, image 1 of 3 Opening Procedure, Remove the back cover assembly: step 6, image 2 of 3 Opening Procedure, Remove the back cover assembly: step 6, image 3 of 3
      • Remove the back cover assembly.
      Ask FixBot
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
4 other people completed this guide.
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Whelp. I got it open thanks to this guide, but there's nothing I can see that would fix my main/power button not being responsive (thus the watch won't turn on anymore). Thanks anyway!
Hailey R - Reply Share
Heb de batterij van mijn Ticwatch Pro 3 ultra succesvol kunnen vervangen. Ik zou enkel de specialized watch adhesive tape nog moeten hebben voor deze horloge om hem terug waterproof te hebben?
Patrick Vercammen - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 108
All Time: 2,849
