Tools
Safety Glasses4.7
ESD Gloves4.5
Introduction
Go to step 1 ↓Use this guide to open your Apple Watch Series 7 for repairs.
Note: The opening procedure for the 41 mm and the 45 mm Apple Watch series 7 is the same. You can use this guide for both models.
This guide shows the procedure on the cellular/LTE version of the watch, but the GPS-only version is similar.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before starting repairs, take your watch off the charger and power it down.
Because the gap between the screen and watch body is so thin, an iFlex is needed to separate the two.
Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
Tool used on this step:Cut-Resistant ESD Gloves$19.99
Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
With one hand, push down firmly on the watch's frame to secure it in place.
With your free hand, hold the iFlex and push the edges up to make it more rigid.
Pry up the screen enough for the iFlex to lay flat on its own.
Leave the iFlex inserted under the screen.
Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
Insert an opening pick between the screen and iFlex.
Remove the iFlex.
Slide the opening pick around the bottom left corner and up the left edge.
Lift the display and carefully pull it towards the watch crown.
Swing the display open to an upward position.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
