Up to 20% off select tools
Opening Philips Senseo Quadrante
Views: 27K
View statistics:
Past 24 Hours:
23
Past 7 Days:
162
Past 30 Days:
663
All Time:
26,563
Comments: 3
3 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
For most repairs the Senseo has to be opened. The opening procedure is shown here.
    1. Opening Philips Senseo Quadrante, Opening Philips Senseo Quadrante: step 1, image 1 of 2 Opening Philips Senseo Quadrante, Opening Philips Senseo Quadrante: step 1, image 2 of 2
      • Never forget: Power off and unplug your device before starting repairs!
      • Remove all attachments such as cup rack, pod holder and water tank.
      Ask FixBot
    2. Opening Philips Senseo Quadrante: step 2, image 1 of 1
      • Turn the device so that the rear of the machine is facing you.
      • Remove the two Torx T15 screws at the bottom on the machine.
      Ask FixBot
    3. Opening Philips Senseo Quadrante: step 3, image 1 of 1
      • The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
      • There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
      • Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
      Ask FixBot
    4. Opening Philips Senseo Quadrante: step 4, image 1 of 2 Opening Philips Senseo Quadrante: step 4, image 2 of 2
      • At this point, the side panel is still snapped into place on the front, right next to the coffee spout. You can use a screwdriver to carefully pry the latch open.
      • On the inside of the side panel there are two pegs on the top edge that fit in the holes. Lift the side panel up and out.
      Ask FixBot
    5. Opening Philips Senseo Quadrante: step 5, image 1 of 1
      • The heating element can be seen immediately after the side panel is removed.
      Ask FixBot
    6. Opening Philips Senseo Quadrante: step 6, image 1 of 3 Opening Philips Senseo Quadrante: step 6, image 2 of 3 Opening Philips Senseo Quadrante: step 6, image 3 of 3
      • User a screwdriver to release the catch at the top of the electronics cover.
      • Lift out the cover.
      • Both the electronics and the pump will be visible once the cover is removed.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
11 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,359 Reputation
324 Guides authored
3 Guide Comments
Descriptifs et photos des opérations bien détaillés, pour mon HD 7864.
Un petit détail pour le démontage du disque de distribution d'eau il y a une encoche avec 2 flèches face à face, faire levier avec petit tournevis pour le déclipser. Merci bonne continuation 😉👍
Gerard - Reply Share
Bonjour pouvez vous faire une photo avec l encoche et les deux flèches
Merci
momy fedida - Reply Share
Re bonjour j ai trouvé où se trouver les deux flèches merci
Past 24 Hours: 23
Past 7 Days: 162
Past 30 Days: 663
All Time: 26,563
