Open the housing
    1. Open the housing, Housing: step 1, image 1 of 2 Open the housing, Housing: step 1, image 2 of 2
      • Never forget: Unplug the machine!
      • Remove all attachments such as the water tank, brewing unit, bean compartment lid, and drip tray. Remove all coffee beans.
      • Turn the machine over so that the back is facing you. Remove the two Torx T10 screws at the bottom. Pull the back out slightly at the bottom and lift it down.
      • Important components are immediately visible:
      • The main circuit board
      • The pump
      • The flow meter
      • The boiler
      Ask FixBot
    2. Open the housing: step 2, image 1 of 2 Open the housing: step 2, image 2 of 2
      • Unscrew the Torx T10 screw on the finger guard in the coffee bean compartment.
      • Lift out the finger guard.
      • The screw is especially long.
      • Unscrew the three Torx T10 screws in the coffee bean compartment.
      Ask FixBot
    3. Open the housing: step 3, image 1 of 3 Open the housing: step 3, image 2 of 3 Open the housing: step 3, image 3 of 3
      • Lift the upper cover slightly at the rear edge.
      • Then lift the cover completely off.
      • When reassembling, make sure that the grinder adjustment is correctly positioned.
      • Figure 3 shows the grinding mechanism, which can now easily be removed.
      Ask FixBot
    4. Open the housing: step 4, image 1 of 3 Open the housing: step 4, image 2 of 3 Open the housing: step 4, image 3 of 3
      • Unscrew the two Torx T10 screws at the bottom of the front.
      • Slide the right side panel back slightly and remove it.
      • Slide the left side panel back slightly and remove it.
      Ask FixBot
    5. Open the housing: step 5, image 1 of 2 Open the housing: step 5, image 2 of 2
      • Other important components:
      • The boiler
      • Valve block, consisting of four solenoid valves
      • Grinder
      • Drive
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
342,143 Reputation
315 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
40 Members
7,000 Guides authored
0 Guide Comments
Past 24 Hours: 20
Past 7 Days: 88
Past 30 Days: 414
All Time: 5,606
