Open and clean a Sodastream Crystal
Views: 33K
View statistics:
Past 24 Hours:
65
Past 7 Days:
537
Past 30 Days:
2,548
All Time:
33,463
Comments: 27
13 comments on steps, 14 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
These instructions show how to open a Sodastream Crystal carbonator. You can then clean it, adjust the valve and change the gaskets.
Tools
    1. Open and clean a Sodastream Crystal, Carbonation unit cover: step 1, image 1 of 3 Open and clean a Sodastream Crystal, Carbonation unit cover: step 1, image 2 of 3 Open and clean a Sodastream Crystal, Carbonation unit cover: step 1, image 3 of 3
      • Lift the cover over the carbonation unit with a suitable tool, e.g. a metal spatula.
      • The cover on this appliance was already calcified by too much water.
      Ask FixBot
    2. Open and clean a Sodastream Crystal, Dismantling the supply line: step 2, image 1 of 1
      • Carefully loosen the union nut on the gas supply line. Be very careful, all parts are made of plastic.
      • Do not tighten this nut too much when assembling. Tightening with your fingers is sufficient.
      • If the nut does break, you can recreate it with a 3D printer.
      • Pull off the hose.
      • If the water runs out of the side of the appliance, try tightening the valve slightly. Gradually turn the plastic screw clockwise about a quarter of a turn and then test each time until no more water is pressed out.
      Ask FixBot
    3. Open and clean a Sodastream Crystal, Lifting off the upper housing: step 3, image 1 of 3 Open and clean a Sodastream Crystal, Lifting off the upper housing: step 3, image 2 of 3 Open and clean a Sodastream Crystal, Lifting off the upper housing: step 3, image 3 of 3
      • Loosen the two Phillips screws that secure the upper part of the housing.
      • Lift the housing part upwards. It will be stuck a little, you have to pull firmly with care.
      • Pay attention to the gas supply line. Unthread it from the slot at the top.
      Ask FixBot
    4. Open and clean a Sodastream Crystal: step 4, image 1 of 3 Open and clean a Sodastream Crystal: step 4, image 2 of 3 Open and clean a Sodastream Crystal: step 4, image 3 of 3
      • The two valves are now easily accessible. They were very dirty on this appliance and urgently needed cleaning.
      Ask FixBot
    5. Open and clean a Sodastream Crystal, Remove Valves: step 5, image 1 of 3 Open and clean a Sodastream Crystal, Remove Valves: step 5, image 2 of 3 Open and clean a Sodastream Crystal, Remove Valves: step 5, image 3 of 3
      • Unscrew the two long Phillips screws on the two valves.
      • Be careful, the valve breaks very easily (Fig. 2) if you tighten the screws too much. This is not necessary, the O-rings remain tight even if the screws are almost loose.
      • Pull off the valves. Be careful not to loose the two O-rings.
      Ask FixBot
    6. Open and clean a Sodastream Crystal, Remove the pressure plate: step 6, image 1 of 3 Open and clean a Sodastream Crystal, Remove the pressure plate: step 6, image 2 of 3 Open and clean a Sodastream Crystal, Remove the pressure plate: step 6, image 3 of 3
      • Remove the spring from the pressure plate with your fingers.
      • Lift the pressure plate at its rotation axis.
      • Remove the pressure plate.
      Ask FixBot
    7. Open and clean a Sodastream Crystal, Lifting out the push rod: step 7, image 1 of 2 Open and clean a Sodastream Crystal, Lifting out the push rod: step 7, image 2 of 2
      • Lift out the push rod.
      Ask FixBot
    8. Open and clean a Sodastream Crystal, Remove cover: step 8, image 1 of 2 Open and clean a Sodastream Crystal, Remove cover: step 8, image 2 of 2
      • Remove the three Phillips screws securing the top cover of the carbonation unit.
      • Lift off the cover. Caution: The carbonation unit is loose and may fall out. It might be more convenient to work with the device lying flat on your work surface.
      Ask FixBot
    9. Open and clean a Sodastream Crystal, Remove carbonation unit: step 9, image 1 of 1
      • Press the carbonation unit downwards out of the metal cylinder.
      Ask FixBot
    10. Open and clean a Sodastream Crystal: step 10, image 1 of 2 Open and clean a Sodastream Crystal: step 10, image 2 of 2
      • Here are the most important components.
      • Now you can descale, clean and disinfect all parts, e.g. with alcohol.
      • If gaskets are defective, replace them now.
      • The second picture shows a disassembled valve for information purposes. Normally, you should not open the valve. The O-ring on the valve piston may be defective.
      Ask FixBot
    11. Open and clean a Sodastream Crystal: step 11, image 1 of 2 Open and clean a Sodastream Crystal: step 11, image 2 of 2
      • To access the gaskets, you can also unscrew the lower retaining plate.
      Ask FixBot
    12. Open and clean a Sodastream Crystal: step 12, image 1 of 2 Open and clean a Sodastream Crystal: step 12, image 2 of 2
      • Photos of the seal ring from above and laterally.
      Ask FixBot
    13. Open and clean a Sodastream Crystal, Notes for assembly: step 13, image 1 of 3 Open and clean a Sodastream Crystal, Notes for assembly: step 13, image 2 of 3 Open and clean a Sodastream Crystal, Notes for assembly: step 13, image 3 of 3
      • To ensure that the mechanism works properly again, follow these instructions for reassembly:
      • Grease all moving parts with a little food-safe silicone grease.
      • Make sure that the small pin at the top of the carbonation unit fits into the hole on the metal cylinder.
      • The cut-out in the top cover of the bubbler unit must fit over the bar to limit the angle of rotation.
      • When inserting the metal cylinder, make sure that the pin engages in the approx. 1.5 cm wide pocket on the large plastic ring, otherwise the cylinder will not be properly inserted.
      • Before you push the black lid back in at the top, fill a carafe with water and check that everything is tight.
      Ask FixBot
Congratulations on your successful repair!
13 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
344,807 Reputation
317 Guides authored
14 Guide Comments
Super, danke für die Anleitung! Habe damit erfolgreich einen verschlissenen Dichtungsring am Ventilkolben getauscht und alles gereinigt. Die Anleitung war super leicht verständlich und eindeutig und die ganzen Hinweise super hilfreich. Ich war beim Zusammenbau erst zu vorsichtig beim Anziehen der Überwurfmutter der Gaszuleitung und musste dann auf die Suche nach dem Leck gehen. Kräftiges Anziehen mit den Fingern war aber tatsächlich ausreichend, um alles wieder dicht zu bekommen.
Lukas E - Reply Share
Sehr gerne, freut mich sehr.
VauWeh - Reply Share
Danke auch von mir für die Anleitung, das Ding ist ein Biest, wenn man es auseinander bauen muss.
Bei mir klemmt nun nach einer angebrochenen Mutter der Metallzylinder und er lässt sich nicht mehr bewegen. Mein Problem beim Auseinanderbauen ist das abheben des oberen Gehäuses.
Du schreibst "Es klemmt etwas, du musst kräftig mit Gefühl ziehen." - bei mir hebt sich nur die linke Seite an, die rechte sitzt sehr fest. Gibt es da einen Trick?
huedrant - Reply Share
Soweit ich mich erinnere saß das Ding zwar ziemlich fest, mit etwas Kraft gings dann aber ab. Vorsichtige Schläge mit einem Holzstück helfen vielleicht.
Perfekt, vielen Dank für den Hinweis! Hochziehen und dabei seitlich mit Holz (ich habe eine Glasglasche benutzt) dranschlagen hat geholfen! @vauweh
Past 24 Hours: 65
Past 7 Days: 537
Past 30 Days: 2,548
All Time: 33,463
