Introduction
Go to step 1 ↓Most repairs require opening the device. The housing is held together by a few screws and many clips. You will need patience and some strength.
Tools
Remove all attachments such as the water tank, grounds drawer, and brewing unit.
Remove the coffee container lid and empty all coffee beans.
Image 1 shows the four clips on the water tank side for reference. They are difficult to reach, especially the two at the front, which require some force, but they can still break off. The cover will still hold securely.
Image 2 shows the clips in the curve for the water tank. They are still easy to reach from the inside.
This clip in image 2 is one of three on the back that are easy to reach. See image 3 for more.
Start at the rear to release the clips. To do this, you need to push them quite far inwards with a suitable tool or your fingers while levering the upper cover upwards with a plastic tool. Finally, you need a little force and dexterity to remove the cover at the front on the water tank side.
Place the machine on its side and press the two catches inwards from the underside.
Remove the side panel by using a little force. Do not remove it completely, as it is still connected to cables and hoses.
The work is easier if you release the catch at the bottom of the black water level sensor and slide the sensor out. Disconnect the hoses from the small white flow meter, pull out the flow meter, and the cover is now released.
Follow the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
10 Guide Comments
Hallo, vielen Dank für die Anleitung – sie hat mir sehr geholfen. Ich habe allerdings das Problem, dass bei meiner Kaffeemaschine kein Wasser durchläuft. Die Pumpe fördert das Wasser direkt in die Tropfschale. Können Sie mir vielleicht weiterhelfen?
Leider ist die EQ 500 eine ziemlich ungewöhnliche Konstruktion und oft schwierig zu reparieren. Hilft der Testmodus in irgendeiner Weise, um festzustellen, wo das Wasser den falschen Weg nimmt? Die Steuerung des Wasserflusses geschieht unter dem großen Zahnrad oben in der Maschine. Viele Hinweise gibt es in diesem Video (und anderen vom gleichen Autor).
Kann leider kein Bild einfügen, das ist oben am Türträger die Verriegelung.
https://www.ersatzteilshop.de/tuer-traeg...;
So ein neuen Türträger habe ich bereits da, aber wie ich den tauschen kann weiß ich leider nicht
Meine Maschine macht keinen Milchschaum mehr. Die Milch läuft einfach leicht erwärmt durch ohne Schaum. Woran kann das liegen?
Ich habe bereits die Maschine, sowie Milchbehälter mehrfach entkalkt und gereinigt.
Weiß nicht mehr weiter. Bzw. woran kann es im Inneren liegen?
