Open Kobold VK150 case
Views: 15K
View statistics:
Past 24 Hours:
5
Past 7 Days:
39
Past 30 Days:
177
All Time:
15,372
Comments: 3
3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Open Kobold VK150 case, Remove screws from housing: step 1, image 1 of 2 Open Kobold VK150 case, Remove screws from housing: step 1, image 2 of 2
      • Use a TX10 screwdriver
      • Remove the housing screws on the rear of the device.
      • 6 long screws
      • 3 short screws
      Ask FixBot
    2. Open Kobold VK150 case, Remove housing cover: step 2, image 1 of 1
      • Place the device with the white lid facing up.
      • Start to carefully lift the lid at the front of the suction nozzle. Slowly work your way up to the stem.
      • At the top of the stem, a small plastic part holds in the gray casing of the suction cup!
      Ask FixBot
    3. Open Kobold VK150 case, Separate parts: step 3, image 1 of 1
      • Now you can lift the flap of the vacuum cleaner bag. This was only held by the white lid.
      Ask FixBot
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Lukas Fritz
410 Reputation
3 Guides authored
3 Guide Comments
Sehr gute Beschreibung !
Ich habe im Augenblick so einen “Problembürger”.
Der geht nicht .
Wenn der Motor überbrückt wird läuft der Staubsauger .
Könnte vielleicht der Schalter sein??
Das Kabel habe ich geprüft,ist i.O.
Vielleicht hast du einen Tip!
Vielen Dank im voraus.
Jo
Jo Pe - Reply Share
Der Deckel für den Beutel schließt nicht mehr
Mikael - Reply Share
kobold vk150 der deckel vom staubbeutelfach schliesst nicht mehr richtig
Past 24 Hours: 5
Past 7 Days: 39
Past 30 Days: 177
All Time: 15,372
