Oontz Angle 3 ULTRA Back Panel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
56
All Time:
1,234
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will help you open up your Oontz Angle 3 Ultra, which will allow you to work on its sensitive internals. To open up the speaker, you must remove the back panel to access the inner components of the device.
Tools
    1. Oontz Angle 3 ULTRA Back Panel Replacement, Back Panel: step 1, image 1 of 3 Oontz Angle 3 ULTRA Back Panel Replacement, Back Panel: step 1, image 2 of 3 Oontz Angle 3 ULTRA Back Panel Replacement, Back Panel: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the two black rubber sheaths around the edges of the speaker.
      • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
      • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
      Ask FixBot
    2. Oontz Angle 3 ULTRA Back Panel Replacement: step 2, image 1 of 3 Oontz Angle 3 ULTRA Back Panel Replacement: step 2, image 2 of 3 Oontz Angle 3 ULTRA Back Panel Replacement: step 2, image 3 of 3
      • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
      Ask FixBot
    3. Oontz Angle 3 ULTRA Back Panel Replacement: step 3, image 1 of 3 Oontz Angle 3 ULTRA Back Panel Replacement: step 3, image 2 of 3 Oontz Angle 3 ULTRA Back Panel Replacement: step 3, image 3 of 3
      • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
      Ask FixBot
    4. Oontz Angle 3 ULTRA Back Panel Replacement: step 4, image 1 of 3 Oontz Angle 3 ULTRA Back Panel Replacement: step 4, image 2 of 3 Oontz Angle 3 ULTRA Back Panel Replacement: step 4, image 3 of 3
      • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
      • Remove the back panel off of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 56
All Time: 1,234
