OontZ Angle 3 Speaker Replacement
    1. OontZ Angle 3 Speaker Replacement, Back Case: step 1, image 1 of 3 OontZ Angle 3 Speaker Replacement, Back Case: step 1, image 2 of 3 OontZ Angle 3 Speaker Replacement, Back Case: step 1, image 3 of 3
      • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
      • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
      Ask FixBot
    2. OontZ Angle 3 Speaker Replacement: step 2, image 1 of 1
      • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
      Ask FixBot
    3. OontZ Angle 3 Speaker Replacement: step 3, image 1 of 2 OontZ Angle 3 Speaker Replacement: step 3, image 2 of 2
      • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
      Ask FixBot
    1. OontZ Angle 3 Speaker Replacement, Speaker: step 4, image 1 of 2 OontZ Angle 3 Speaker Replacement, Speaker: step 4, image 2 of 2
      • Use the plastic opening tool to remove the front speaker plate from the speaker.
      Ask FixBot
    2. OontZ Angle 3 Speaker Replacement: step 5, image 1 of 2 OontZ Angle 3 Speaker Replacement: step 5, image 2 of 2
      • Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
      • Open access to the speakers by letting them rest as shown.
      Ask FixBot
    3. OontZ Angle 3 Speaker Replacement: step 6, image 1 of 2 OontZ Angle 3 Speaker Replacement: step 6, image 2 of 2
      • Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
      • Learn more about soldering here.
      • Remove the disconnected speaker(s).
      • When reconnecting the wires to the new speaker(s), be careful to connect the wires to the correct nodes (red for positive and black for negative). If they are reconnected to the wrong locations the speakers will either not work or break.
      Ask FixBot
13 other people completed this guide.
Mason Hollander
1,604 Reputation
4 Guides authored
USF Tampa, Team 15-6, Remmell Spring 2016 Member of USF Tampa, Team 15-6, Remmell Spring 2016
USFT-REMMELL-S16S15G6
4 Members
48 Guides authored
8 Guide Comments
Where do you buy replacement speakers?
michalfiona - Reply Share
Where do you buy the replacement speakers?
What type to buy?
where i buy the speaker replacement/
Sharina Uadan - Reply Share
Where can i buy the replacement speakers
Anil Meda - Reply Share
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
Dwayne Champ Manuel - Reply Share
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 108
All Time: 10,274
