Onkyo TX-800 Power fuse Replacement
    1. Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: step 1, image 1 of 3 Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: step 1, image 2 of 3 Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: step 1, image 3 of 3
      • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
      Ask FixBot
    2. Onkyo TX-800 Power fuse Replacement: step 2, image 1 of 2 Onkyo TX-800 Power fuse Replacement: step 2, image 2 of 2
      • Remove the top screw on the back panel.
      Ask FixBot
    3. Onkyo TX-800 Power fuse Replacement: step 3, image 1 of 2 Onkyo TX-800 Power fuse Replacement: step 3, image 2 of 2
      • Slide off the case to expose the internal components of the receiver.
      Ask FixBot
    1. Onkyo TX-800 Power fuse Replacement, Power fuse: step 4, image 1 of 2 Onkyo TX-800 Power fuse Replacement, Power fuse: step 4, image 2 of 2
      • Locate the fuse.
      Ask FixBot
    2. Onkyo TX-800 Power fuse Replacement: step 5, image 1 of 2 Onkyo TX-800 Power fuse Replacement: step 5, image 2 of 2
      • Gently wedge a small screwdriver in between one side of the fuse and the contact.
      • Remove the fuse with your thumb and forefinger.
      Ask FixBot
    3. Onkyo TX-800 Power fuse Replacement: step 6, image 1 of 1
      • Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
      Ask FixBot
Finish Line
6 other people completed this guide.
Michael Lady
313 Reputation
2 Guides authored
Cal Poly, Team 27-92, Amido Spring 2010 Member of Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Members
84 Guides authored
2 Guide Comments
Thanks for clear instructions!
Andy Dersch - Reply Share
Thank you!
There are no Onkyo repair centers to go to.
obobooks - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 70
All Time: 21,253
