Up to 20% off select tools
OnePlus X Battery Replacement
Views: 36K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
124
All Time:
35,558
Comments: 18
10 comments on steps, 8 guide comments.
Go to guide comments
Completed: 28
28 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
The battery of the OnePlus X is located behind the glass rear panel. Use this guide to remove the battery and disconnect it from the motherboard.
    1. OnePlus X Battery Replacement, Rear Panel: step 1, image 1 of 2 OnePlus X Battery Replacement, Rear Panel: step 1, image 2 of 2
      • Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
      • Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
      • Select "Power Off" on the screen to turn off the phone.
      Ask FixBot
    2. OnePlus X Battery Replacement: step 2, image 1 of 3 OnePlus X Battery Replacement: step 2, image 2 of 3 OnePlus X Battery Replacement: step 2, image 3 of 3
      • Insert a SIM card removal tool into the small hole located on the top right corner of the phone, just above the volume buttons.
      • If you do not have the original packaging or a SIM card removal tool, you may use a straightened out paperclip or something similar.
      • Push the removal tool into the hole and the tray should pop out.
      • Remove the SIM tray from the phone.
      Ask FixBot
    3. OnePlus X Battery Replacement: step 3, image 1 of 3 OnePlus X Battery Replacement: step 3, image 2 of 3 OnePlus X Battery Replacement: step 3, image 3 of 3
      • Put on heat-resistant gloves and place the phone on a surface that will not catch fire or melt.
      • Using a heat gun, apply slow and even heat to the edges of the back panel.
      • DO NOT stay on one spot for too long, the heat gun can damage the phone if the heat is applied to the same area for a long period of time.
      • While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
      • Carefully detach the back panel, using opening picks to hold the panel apart from the device.
      • Once most of the edges are separated from the device, attach a suction cup to the back panel.
      Ask FixBot
    4. OnePlus X Battery Replacement: step 4, image 1 of 3 OnePlus X Battery Replacement: step 4, image 2 of 3 OnePlus X Battery Replacement: step 4, image 3 of 3
      • Press the suction cup to the back panel to secure it.
      • With the help of the suction cup, pull up on the panel to completely detach it from the device.
      • Use the suction cup to safely remove the panel from the device. As you work around the panel's edges, the lingering heat may cause the remaining adhesive to reattach the panel to the device, be sure to lift the back panel before the glue has time to set back.
      Ask FixBot
    1. OnePlus X Battery Replacement, Battery: step 5, image 1 of 3 OnePlus X Battery Replacement, Battery: step 5, image 2 of 3 OnePlus X Battery Replacement, Battery: step 5, image 3 of 3
      • Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
      • Four (longer) PH000 screws
      • Three shorter PH000 screws
      • Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
      • There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
      Ask FixBot
    2. OnePlus X Battery Replacement: step 6, image 1 of 2 OnePlus X Battery Replacement: step 6, image 2 of 2
      • Once the metal cover is removed, locate the battery connector wire, which clips into the motherboard.
      • Using a plastic spudger, gently pry on the clip to release it.
      • This will cut power to the phone, and prevent any power running to any of the components which is important while working on the phone.
      Ask FixBot
    3. OnePlus X Battery Replacement: step 7, image 1 of 3 OnePlus X Battery Replacement: step 7, image 2 of 3 OnePlus X Battery Replacement: step 7, image 3 of 3
      • On the battery, locate a clear tab. This will be used to pull the battery out.
      • Firmly grasp the clear tab and pull up and away from the phone to remove the battery.
      • Take your time during this step, as you do not want to apply too much force and damage the battery.
      • There is an adhesive underneath the battery so it might be useful to utilize the black plastic spudger to get between the battery and the phone to pry the battery up but be very careful not to break the ribbon cables underneath the battery.
      • Continue to pull slowly on the battery, until it is completely free from the phone.
      Ask FixBot
28 other people completed this guide.
Author
with
Luis Castro
2,073 Reputation
4 Guides authored
USF Tampa, Team 3-6, Wollert Spring 2016 Member of USF Tampa, Team 3-6, Wollert Spring 2016
USFT-WOLLERT-S16S3G6
2 Members
60 Guides authored
8 Guide Comments
Thanks! This is cool! I didn't know I can replace my OnePlus X's battery :)
Antonius Harijanto - Reply Share
how to stick back panel to the device again?
Sarthak Ahir - Reply Share
Double sided adhesive
Maxime LUCAS - Reply Share
Does someone know a good vendor for a new Battery for the OPX that sells in europ? I also want to change the battery after 2 1/2 years.
Thanks in advance =)
Det Maat - Reply Share
I just bought this :-) https://www.ebay.de/itm/382548678130
soren1967 - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 124
All Time: 35,558
