OnePlus Nord N200 Sub Board Replacement
    1. OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: step 1, image 1 of 3 OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: step 1, image 2 of 3 OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: step 1, image 3 of 3
      • Take sim tray out prior to beginning repair.
      • Heat back of phone to make the adhesion more pliable
      • Insert a slim prying tool to begin removing the back cover, move in a counterclockwise direction
      • Add IPA as you work to detatch the adhesion layer
      • When approaching the volume button, be cautious, as the ribbon cable is exposed and can easilyt be cut
      • Remove back cover
      Ask FixBot
    2. OnePlus Nord N200 Sub Board Replacement: step 2, image 1 of 3 OnePlus Nord N200 Sub Board Replacement: step 2, image 2 of 3 OnePlus Nord N200 Sub Board Replacement: step 2, image 3 of 3
      • Using a J000 screwdriver, remove the Screws holding the edge casing to the screen (19 Total)
      • Using a pry tool, seperate the edge plastic from the screen
      • Once you have attained suitable lift, disconnect the power button cable.
      • Remove the edge plastic and set aside.
      Ask FixBot
    3. OnePlus Nord N200 Sub Board Replacement: step 3, image 1 of 1
      • Remove the plastic speaker piece
      • Disconnect the antenna cables and main board connector
      • Remove the board and insert new component
      • reconnect connectors
      Ask FixBot
    4. OnePlus Nord N200 Sub Board Replacement: step 4, image 1 of 3 OnePlus Nord N200 Sub Board Replacement: step 4, image 2 of 3 OnePlus Nord N200 Sub Board Replacement: step 4, image 3 of 3
      • Reconnect the antenna and main board
      • Reconnect the power cable, and reattach the plastic edge
      • Using J000, screw the 19 screws back in
      Ask FixBot
    5. OnePlus Nord N200 Sub Board Replacement: step 5, image 1 of 2 OnePlus Nord N200 Sub Board Replacement: step 5, image 2 of 2
      • Reconnect the back plastic, and set on heat to adhere
      • You can also use tesa tape to increase the adhesion.
      Ask FixBot
This order can be used for charger, headphone jack, or water damage to sub board.
Jesse Smith
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 73
All Time: 1,840
