OnePlus Nord N20 5G Daughterboard Replacement
  1. OnePlus Nord N20 5G Daughterboard Replacement, Back Cover: step 1, image 1 of 1
    • Insert the SIM ejection tool or a spudger in the small hole next to the SIM tray.
    • Push it gently until the tray pops out.
    • Remove the SIM card tray by sliding it outwards.
  2. OnePlus Nord N20 5G Daughterboard Replacement: step 2, image 1 of 2 OnePlus Nord N20 5G Daughterboard Replacement: step 2, image 2 of 2
    • Heat the iOpener in a microwave for about 30 seconds. If the iOpener isn’t hot enough, reheat it for another 10-30 seconds.
    • Apply the heated iOpener on the backside of the phone for a minute to loosen the adhesive.
    • Use the iFixit opening tool and slide it along the edges of the phone to pry the back panel off.
  3. OnePlus Nord N20 5G Daughterboard Replacement, Speaker: step 3, image 1 of 1
    • Remove the 18 3.9 mm screws using a Phillips #0 screwdriver.
  4. OnePlus Nord N20 5G Daughterboard Replacement: step 4, image 1 of 1
    • Take the iFixit opening tool and run it along the edges of the frame.
    • Separate the back housing from the frame of the screen.
  5. OnePlus Nord N20 5G Daughterboard Replacement: step 5, image 1 of 3 OnePlus Nord N20 5G Daughterboard Replacement: step 5, image 2 of 3 OnePlus Nord N20 5G Daughterboard Replacement: step 5, image 3 of 3
    • Use a spudger to gently lift the speaker, disconnecting it from the motherboard.
    • Remove the speaker from the device.
  6. OnePlus Nord N20 5G Daughterboard Replacement, Daughterboard: step 6, image 1 of 3 OnePlus Nord N20 5G Daughterboard Replacement, Daughterboard: step 6, image 2 of 3 OnePlus Nord N20 5G Daughterboard Replacement, Daughterboard: step 6, image 3 of 3
    • Disconnect the bracket attached to the daughterboard.
    • Disconnect the black and white wire.
  7. OnePlus Nord N20 5G Daughterboard Replacement: step 7, image 1 of 2 OnePlus Nord N20 5G Daughterboard Replacement: step 7, image 2 of 2
    • Remove the daughterboard.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 343
