OnePlus Nord N20 5G Battery Replacement
    1. OnePlus Nord N20 5G Battery Replacement, Back Cover: step 1, image 1 of 1
      • Insert the SIM ejection tool or a spudger in the small hole next to the SIM tray.
      • Push it gently until the tray pops out.
      • Remove the SIM card tray by sliding it outwards.
      Ask FixBot
    2. OnePlus Nord N20 5G Battery Replacement: step 2, image 1 of 2 OnePlus Nord N20 5G Battery Replacement: step 2, image 2 of 2
      • Heat the iOpener in a microwave for about 30 seconds. If the iOpener isn’t hot enough, reheat it for another 10-30 seconds.
      • Apply the heated iOpener on the backside of the phone for a minute to loosen the adhesive.
      • Use the iFixit opening tool and slide it along the edges of the phone to pry the back panel off.
      Ask FixBot
    1. OnePlus Nord N20 5G Battery Replacement, Battery: step 3, image 1 of 3 OnePlus Nord N20 5G Battery Replacement, Battery: step 3, image 2 of 3 OnePlus Nord N20 5G Battery Replacement, Battery: step 3, image 3 of 3
      • Remove the eighteen 3.9 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. OnePlus Nord N20 5G Battery Replacement: step 4, image 1 of 2 OnePlus Nord N20 5G Battery Replacement: step 4, image 2 of 2
      • Take the iFixit opening tool and run it along the edges of the frame.
      • Separate the back housing from the frame of the screen.
      Ask FixBot
    3. OnePlus Nord N20 5G Battery Replacement: step 5, image 1 of 2 OnePlus Nord N20 5G Battery Replacement: step 5, image 2 of 2
      • Disconnect the brackets attached to the motherboard with the help of a spudger.
      Ask FixBot
    4. OnePlus Nord N20 5G Battery Replacement: step 6, image 1 of 2 OnePlus Nord N20 5G Battery Replacement: step 6, image 2 of 2
      • Remove the tape that's covering the battery.
      • Pull up the battery using the green tape on the right side of the battery.
      • Now you can replace the old battery with your new one.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 29
Past 30 Days: 110
All Time: 1,529
