OnePlus Nord 2 5G Daughterboard Replacement
    1. OnePlus Nord 2 5G Daughterboard Replacement, Eject the SIM card tray: step 1, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Eject the SIM card tray: step 1, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM card eject tool into the small hole in the SIM card tray, located on the upper left edge edge of the phone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. OnePlus Nord 2 5G Daughterboard Replacement, Remove the SIM card tray: step 2, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Remove the SIM card tray: step 2, image 2 of 2
      • Remove the SIM card tray from the phone.
      • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
      • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
      Ask FixBot
    1. OnePlus Nord 2 5G Daughterboard Replacement, Loosen the rear glass: step 3, image 1 of 1
      • Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. OnePlus Nord 2 5G Daughterboard Replacement, Insert an iFlex: step 4, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Insert an iFlex: step 4, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Insert an iFlex: step 4, image 3 of 3
      • Due to its surface, no suction tool will hold onto the phone's rear glass. A thin slicing tool is required to create a gap between the rear glass and the midframe.
      • Insert an iFlex into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap. This may require some force.
      • Leave the iFlex in place to prevent the adhesive from resealing.
      Ask FixBot
    3. OnePlus Nord 2 5G Daughterboard Replacement, Insert an opening pick: step 5, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Insert an opening pick: step 5, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Insert an opening pick: step 5, image 3 of 3
      • Insert an opening pick into the gap you created with the iFlex.
      • Remove the iFlex.
      Ask FixBot
    4. OnePlus Nord 2 5G Daughterboard Replacement, Slice the bottom edge adhesive: step 6, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Slice the bottom edge adhesive: step 6, image 2 of 2
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    5. OnePlus Nord 2 5G Daughterboard Replacement: step 7, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement: step 7, image 2 of 2
      • Insert a second opening pick at the bottom right corner of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    6. OnePlus Nord 2 5G Daughterboard Replacement, Slice the left edge adhesive: step 8, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Slice the left edge adhesive: step 8, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Slice the left edge adhesive: step 8, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. OnePlus Nord 2 5G Daughterboard Replacement, Slice the top edge adhesive: step 9, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Slice the top edge adhesive: step 9, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of the rear glass.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    8. OnePlus Nord 2 5G Daughterboard Replacement, Slice the right edge adhesive: step 10, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Slice the right edge adhesive: step 10, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Slice the right edge adhesive: step 10, image 3 of 3
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
      Ask FixBot
    9. OnePlus Nord 2 5G Daughterboard Replacement, Remove the back cover: step 11, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Remove the back cover: step 11, image 2 of 2
      • Remove the back cover.
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. OnePlus Nord 2 5G Daughterboard Replacement, Remove the connector bracket: step 12, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Remove the connector bracket: step 12, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the metal bracket covering the flash assembly connector.
      Ask FixBot
    2. OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the flash assembly: step 13, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the flash assembly: step 13, image 2 of 2
      • Use the point of a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
      Ask FixBot
    3. OnePlus Nord 2 5G Daughterboard Replacement, Unfasten the motherboard cover: step 14, image 1 of 1
      • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
      Ask FixBot
    4. OnePlus Nord 2 5G Daughterboard Replacement, Pry up the motherboard cover: step 15, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Pry up the motherboard cover: step 15, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Pry up the motherboard cover: step 15, image 3 of 3
      • The motherboard cover is held in place by plastic clips.
      • Insert an opening pick underneath the bottom right edge of the motherboard cover.
      • Twist the opening pick sideways release the plastic clips and to pry up the motherboard cover.
      Ask FixBot
    5. OnePlus Nord 2 5G Daughterboard Replacement, Remove the motherboard cover: step 16, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Remove the motherboard cover: step 16, image 2 of 2
      • Remove the motherboard cover.
      Ask FixBot
    6. OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the battery cable: step 17, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the battery cable: step 17, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. OnePlus Nord 2 5G Daughterboard Replacement, Unfasten the daughterboard cover: step 18, image 1 of 1
      • Removing the daughterboard cover isn't mandatory to replace the battery. However, doing so reduces the risk of damaging surrounding components.
      • Use a Phillips screwdriver to remove the six 3.8 mm-long screws securing the daugtherboard cover.
      Ask FixBot
    2. OnePlus Nord 2 5G Daughterboard Replacement, Pry up the daughterboard cover: step 19, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Pry up the daughterboard cover: step 19, image 2 of 2
      • Insert the point of a spudger underneath the top right edge of the daughterboard cover.
      • Pry upwards to loosen the daughterboard cover.
      • Don't try to remove the daughterboard cover all the way yet. It's still adhered to the loudspeaker.
      Ask FixBot
    3. OnePlus Nord 2 5G Daughterboard Replacement, Remove the daughterboard cover: step 20, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Remove the daughterboard cover: step 20, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Remove the daughterboard cover: step 20, image 3 of 3
      • Fold the daughterboard cover to the left like you would open the front cover of a book.
      • Carefully peel the black tape off of the loudspeaker.
      • Remove the daughterboard cover.
      Ask FixBot
    1. OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the interconnect and the antenna board cables: step 21, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the interconnect and the antenna board cables: step 21, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the interconnect and the antenna board cables: step 21, image 3 of 3
      • Use a spudger to disconnect the interconnect and the antenna board cables by prying the connectors straight up from their socket.
      Ask FixBot
    2. OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the fingerprint sensor and the interconnect cables: step 22, image 1 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the fingerprint sensor and the interconnect cables: step 22, image 2 of 3 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the fingerprint sensor and the interconnect cables: step 22, image 3 of 3
      • Use a spudger to disconnect the fingerprint sensor and the interconnect cables by prying the connectors straight up from their sockets.
      Ask FixBot
    3. OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the display: step 23, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the display: step 23, image 2 of 2
      • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
      Ask FixBot
    4. OnePlus Nord 2 5G Daughterboard Replacement, Unfasten the daughterboard: step 24, image 1 of 1
      • Use a Phillips driver to remove the 2.8 mm-long screw securing the daughterboard.
      Ask FixBot
    5. OnePlus Nord 2 5G Daughterboard Replacement, Pry up the daughterboard: step 25, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Pry up the daughterboard: step 25, image 2 of 2
      • Insert the point of a spudger underneath the top edge of the daughterboard.
      • Pry upwards to loosen the daughterboard.
      • Don't try to remove the daughterboard all the way yet. There's an antenna cable on its bottom that is still connected to it.
      Ask FixBot
    6. OnePlus Nord 2 5G Daughterboard Replacement, Fold over the daughterboard: step 26, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Fold over the daughterboard: step 26, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to carefully fold the daughterboard over in direction of the battery.
      Ask FixBot
    7. OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the antenna cable: step 27, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Disconnect the antenna cable: step 27, image 2 of 2
      • Slide a one arm of a pair of tweezers under the black antenna cable until they're snug against the metal connector.
      • Disconnect the upper antenna cable by prying it straight up from the daughterboard.
      Ask FixBot
    8. OnePlus Nord 2 5G Daughterboard Replacement, Remove the daughterboard: step 28, image 1 of 2 OnePlus Nord 2 5G Daughterboard Replacement, Remove the daughterboard: step 28, image 2 of 2
      • Remove the daughterboard.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus Nord 2 5G answers community for help.
2 other people completed this guide.
Dominik Schnabelrauch
263,708 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,581 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 71
All Time: 2,602
