This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
OnePlus Buds Z replacement battery replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
34
Past 30 Days:
185
All Time:
627
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 hours
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacing the replacement battery in the OnePlus Buds Z is easier than you probably thought. I was a bit surprised myself. Unfortunately, there are still a few stumbling blocks; however, with this guide, you can hopefully avoid them.
Note: The steps are only written out for one of the two buds. Simply proceed analogously for the other one. The internal structure is mirrored, but otherwise exactly the same.
Parts
Tools
    1. OnePlus Buds Z replacement battery replacement, Preparation: step 1, image 1 of 1
      • Remove the earbuds from the charging case and let them run until the replacement batteries have less than 20% charge remaining. This reduces the risk of fire to a minimum if the replacement battery is accidentally damaged or a short circuit occurs.
      Ask FixBot
    2. OnePlus Buds Z replacement battery replacement, Removing the rubber tips: step 2, image 1 of 1
      • Remove the rubber tips by pulling them off.
      Ask FixBot
    3. OnePlus Buds Z replacement battery replacement, Opening the housing: step 3, image 1 of 3 OnePlus Buds Z replacement battery replacement, Opening the housing: step 3, image 2 of 3 OnePlus Buds Z replacement battery replacement, Opening the housing: step 3, image 3 of 3
      • Heat the bud with a hairdryer, a heat gun, or a hot/cold pack.
      • Hold the bud as shown so that the earpiece is pointing diagonally toward you.
      • Carefully apply pressure to the earpiece so that a small gap opens.
      • You should only feel a little resistance. If you feel a lot of resistance, continue heating the bud until the gap opens without any issues.
      Ask FixBot
    4. OnePlus Buds Z replacement battery replacement, Removing adhesive residue: step 4, image 1 of 1
      • Use tweezers to remove the adhesive residue that held the housing together. If necessary, apply more heat to assist with this.
      • Be meticulously careful not to damage the ribbon cable. It is very sensitive to shear forces. Unfortunately, this ended up being my downfall during the process.
      Ask FixBot
    5. OnePlus Buds Z replacement battery replacement, PCB Removal: step 5, image 1 of 2 OnePlus Buds Z replacement battery replacement, PCB Removal: step 5, image 2 of 2
      • Carefully lift the small PCB resting on the replacement battery without damaging the cables. It is best to use a spudger and some heat to assist.
      Ask FixBot
    6. OnePlus Buds Z replacement battery replacement, Remove the replacement battery: step 6, image 1 of 1
      • Now carefully lift the replacement battery. Use blunt tweezers to help and, if necessary, apply heat again.
      Ask FixBot
    7. OnePlus Buds Z replacement battery replacement, Soldering Part I: step 7, image 1 of 2 OnePlus Buds Z replacement battery replacement, Soldering Part I: step 7, image 2 of 2
      Tool used on this step:
      Helping Hands
      $9.99
      Buy
      • Weight the buds down (as shown in image II) or secure them appropriately in a "helping hands with magnifying glass" (AKA "helping hands").
      • Use a soldering iron to first burn off the UV glue and then desolder the cables of the replacement battery.
      • Use new flux, fresh solder, and a desoldering wick if necessary.
      • Remove the remaining solder with a desoldering wick and remove the flux residue with 99 percent isopropyl alcohol and a toothbrush—or better, with an anti-static brush.
      • Make sure to heat the contacts of the replacement battery individually so that a short circuit does not occur accidentally.
      • Ensure adequate smoke extraction or ventilation and use lead-free solder.
      • If you do not have any soldering experience, you may want to watch the soldering course on the iFixit YouTube channel, and then it is best to practice briefly on a defective device (it does not have to be an identical one, you can also learn on a broken Discman).
      Ask FixBot
    8. OnePlus Buds Z replacement battery replacement, Soldering Part II: step 8, image 1 of 1
      No-Clean Flux
      $4.95
      Buy
      • Apply fresh solder to the contacts on the PCB.
      • Solder the new replacement battery to the PCB.
      • Remove the used flux again with 99% isopropyl alcohol.
      • Secure the contact using UV glue or, if not available, a small dab of hot glue.
      • Pay attention to the correct polarity (red +, black -).
      • Also, ensure that you solder the contacts individually so that the replacement battery is not accidentally short-circuited.
      • If necessary, use fresh flux if the connection does not form easily.
      Ask FixBot
    9. OnePlus Buds Z replacement battery replacement, Installing the new replacement battery: step 9, image 1 of 3 OnePlus Buds Z replacement battery replacement, Installing the new replacement battery: step 9, image 2 of 3 OnePlus Buds Z replacement battery replacement, Installing the new replacement battery: step 9, image 3 of 3
      • Place the white retaining ring around the replacement battery.
      • Apply a strip of double-sided adhesive tape to the back of the replacement battery and secure it in the housing.
      • Secure the PCB to the replacement battery with double-sided adhesive tape, aligning it with the red-marked guide tabs on the white retaining ring.
      Ask FixBot
    10. OnePlus Buds Z replacement battery replacement, Closing the housing: step 10, image 1 of 1
      • You can now carefully fold the ribbon cable back and snap the housing together.
      • If you like, you can use a suitable liquid adhesive to close the housing even more securely. Actually, it holds quite well without it, too. However, I would advise against using double-sided tape for the housing. I tore the ribbon cable right through when I tried to apply it.
      Ask FixBot
    11. OnePlus Buds Z replacement battery replacement, The worst case has happened: The ribbon cable is torn - what now?: step 11, image 1 of 3 OnePlus Buds Z replacement battery replacement, The worst case has happened: The ribbon cable is torn - what now?: step 11, image 2 of 3 OnePlus Buds Z replacement battery replacement, The worst case has happened: The ribbon cable is torn - what now?: step 11, image 3 of 3
      Technician's Razor Set
      $14.99
      Buy
      • First of all, the biggest problem: The only available spare parts come from defective buds. You'll therefore have to find some on eBay. Unfortunately, the earpiece itself isn't even available on AliExpress. However, if you have found a spare part, it's not that difficult to fix the earbud.
      • Remove the adhesive strip on the ribbon cable connector.
      • Now remove the UV glue, either using tweezers and a hot air station or – like me – by carefully scraping it off with a scalpel.
      • Now separate the earpiece from the PCB with the help of a spudger.
      • Secure the connection with UV glue or hot glue.
      • Jump back to step 10 and enjoy your great headphones, which will now last for a long train ride again.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Eli
484 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 185
All Time: 627
