OnePlus 9 5G Daughterboard Replacement
    1. OnePlus 9 5G Daughterboard Replacement, Eject the SIM card tray: step 1, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Eject the SIM card tray: step 1, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. OnePlus 9 5G Daughterboard Replacement, Remove the SIM card tray: step 2, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Remove the SIM card tray: step 2, image 2 of 2
      • Remove the SIM card tray from the phone.
      • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
      • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
      Ask FixBot
    1. OnePlus 9 5G Daughterboard Replacement, Loosen the rear glass: step 3, image 1 of 1
      • Completely power off your phone before you begin.
      • Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. OnePlus 9 5G Daughterboard Replacement, Insert an opening pick: step 4, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Insert an opening pick: step 4, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Insert an opening pick: step 4, image 3 of 3
      • Apply a suction handle to the rear glass, as close to the bottom edge as possible.
      • If your rear glass is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the broken rear glass.
      • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. OnePlus 9 5G Daughterboard Replacement, Slice the bottom edge adhesive: step 5, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Slice the bottom edge adhesive: step 5, image 2 of 2
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    4. OnePlus 9 5G Daughterboard Replacement, Insert a second opening pick: step 6, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Insert a second opening pick: step 6, image 2 of 2
      • Insert a second opening pick underneath the bottom edge of the rear glass.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    5. OnePlus 9 5G Daughterboard Replacement, Slice the left edge adhesive: step 7, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Slice the left edge adhesive: step 7, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Slice the left edge adhesive: step 7, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick underneath the bottom left corner of the rear glass.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. OnePlus 9 5G Daughterboard Replacement, Slice the top edge adhesive: step 8, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Slice the top edge adhesive: step 8, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of the rear glass.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    7. OnePlus 9 5G Daughterboard Replacement, Slice the right edge adhesive: step 9, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Slice the right edge adhesive: step 9, image 2 of 2
      • Insert a fifth and final opening pick underneath the top right corner of the rear glass.
      • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
      Ask FixBot
    8. OnePlus 9 5G Daughterboard Replacement, Remove the rear glass: step 10, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Remove the rear glass: step 10, image 2 of 2
      • Remove the rear glass.
      • If the rear glass is still stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
      • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. OnePlus 9 5G Daughterboard Replacement, Peel off the tape: step 11, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Peel off the tape: step 11, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Peel off the tape: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully peel the bottom right corner of the charging coil tape off of the daughterboard cover.
      Ask FixBot
    2. OnePlus 9 5G Daughterboard Replacement: step 12, image 1 of 2 OnePlus 9 5G Daughterboard Replacement: step 12, image 2 of 2
      • Use a pair of tweezers to carefully peel the bottom left corner of the charging coil tape off of the loudspeaker.
      Ask FixBot
    3. OnePlus 9 5G Daughterboard Replacement, Pry up the flash assembly: step 13, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Pry up the flash assembly: step 13, image 2 of 2
      • The flash assembly is held in place by mild adhesive and covers a motherboard cover screw.
      • Carefully slide an opening pick underneath the bottom edge of the flash assembly.
      • Use your opening pick to pry up the flash assembly.
      • Don't try to remove the flash assembly all the way during this procedure. Its cable is adhered to the backside of the motherboard cover.
      Ask FixBot
    4. OnePlus 9 5G Daughterboard Replacement, Unfasten the motherboard cover: step 14, image 1 of 1
      • Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
      • One of the motherboard cover screws is covered by a white water ingress sticker. To unfasten the screw you can puncture the sticker with your screwdriver.
      Ask FixBot
    5. OnePlus 9 5G Daughterboard Replacement, Pry up the motherboard cover: step 15, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Pry up the motherboard cover: step 15, image 2 of 2
      • The motherboard cover is further held in place by tight plastic clips.
      • Insert a spudger underneath the bottom right edge of the motherboard cover.
      • Pry upwards to loosen the motherboard cover and create a gap.
      Ask FixBot
    6. OnePlus 9 5G Daughterboard Replacement: step 16, image 1 of 3 OnePlus 9 5G Daughterboard Replacement: step 16, image 2 of 3 OnePlus 9 5G Daughterboard Replacement: step 16, image 3 of 3
      • Insert an opening pick underneath the bottom right edge of the motherboard cover.
      • Slide the opening pick up along the right edge of the motherboard cover.
      • Twist the opening pick to release the plastic clips and pry up the motherboard cover.
      Ask FixBot
    7. OnePlus 9 5G Daughterboard Replacement, Remove the motherboard cover: step 17, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Remove the motherboard cover: step 17, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the motherboard cover.
      • The charging coil is attached to the motherboard cover and will lift up at the same time.
      Ask FixBot
    8. OnePlus 9 5G Daughterboard Replacement, Disconnect the battery cable: step 18, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Disconnect the battery cable: step 18, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    1. OnePlus 9 5G Daughterboard Replacement, Unfasten the daughterboard cover: step 19, image 1 of 1
      • Use a Phillips screwdriver to remove the five 3.8 mm-long screws securing the daugtherboard cover.
      • One of the daughterboard cover screws is covered by a white water ingress sticker. To unfasten the screw you can puncture the sticker with your screwdriver.
      Ask FixBot
    2. OnePlus 9 5G Daughterboard Replacement, Pry up the daughterboard cover: step 20, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Pry up the daughterboard cover: step 20, image 2 of 2
      • Insert the point of a spudger underneath the top right edge of the daughterboard cover.
      • Pry upwards to loosen the daughterboard cover.
      Ask FixBot
    3. OnePlus 9 5G Daughterboard Replacement, Remove the daughterboard cover: step 21, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Remove the daughterboard cover: step 21, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to remove the daughterboard cover.
      Ask FixBot
    4. OnePlus 9 5G Daughterboard Replacement, Disconnect the interconnect cable: step 22, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Disconnect the interconnect cable: step 22, image 2 of 2
      • Use a spudger to disconnect the interconnect cable from the motherboard by prying the connector straight up from its socket.
      Ask FixBot
    5. OnePlus 9 5G Daughterboard Replacement, Remove the metal bracket: step 23, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Remove the metal bracket: step 23, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Remove the metal bracket: step 23, image 3 of 3
      • Slide one arm of a pair of tweezers underneath the metal bracket covering the interconnect cable.
      • Use your tweezers to lift and unhinge the metal bracket.
      • Remove the metal bracket.
      Ask FixBot
    6. OnePlus 9 5G Daughterboard Replacement, Disconnect the interconnect cable: step 24, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Disconnect the interconnect cable: step 24, image 2 of 2
      • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
      Ask FixBot
    7. OnePlus 9 5G Daughterboard Replacement, Remove the interconnect cable: step 25, image 1 of 1
      • Use a pair of tweezers or your fingers to remove the interconnect cable.
      Ask FixBot
    1. OnePlus 9 5G Daughterboard Replacement, Disconnect the antenna board and fingerprint cables: step 26, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Disconnect the antenna board and fingerprint cables: step 26, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Disconnect the antenna board and fingerprint cables: step 26, image 3 of 3
      • Use a spudger to disconnect the antenna board cable and the fingerprints sensor from the daughterboard by prying the connectors straight up from their sockets.
      Ask FixBot
    2. OnePlus 9 5G Daughterboard Replacement, Disconnect the black coaxial cable: step 27, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Disconnect the black coaxial cable: step 27, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Disconnect the black coaxial cable: step 27, image 3 of 3
      Buy
      • Slide one arm of a pair of tweezers under the black antenna cable until it‘s snug against the metal connector.
      • Disconnect the antenna cable by prying the connector straight up from the daughterboard.
      Ask FixBot
    3. OnePlus 9 5G Daughterboard Replacement, Disconnect the white coaxial cable: step 28, image 1 of 3 OnePlus 9 5G Daughterboard Replacement, Disconnect the white coaxial cable: step 28, image 2 of 3 OnePlus 9 5G Daughterboard Replacement, Disconnect the white coaxial cable: step 28, image 3 of 3
      • Slide one arm of a pair of tweezers under the white antenna cable until it‘s snug against the metal connector.
      Ask FixBot
    4. OnePlus 9 5G Daughterboard Replacement, Unfasten the daughterboard: step 29, image 1 of 1
      • Use a Phillips driver to remove the 2.8 mm-long screw securing the daughterboard.
      Ask FixBot
    5. OnePlus 9 5G Daughterboard Replacement, Pry up the daughterboard: step 30, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Pry up the daughterboard: step 30, image 2 of 2
      • Insert the point of a spudger underneath the top right corner of the daughterboard.
      • Pry upwards to loosen the daughterboard.
      Ask FixBot
    6. OnePlus 9 5G Daughterboard Replacement, Remove the daughterboard: step 31, image 1 of 2 OnePlus 9 5G Daughterboard Replacement, Remove the daughterboard: step 31, image 2 of 2
      • Use a pair of blunt nose tweezers or your fingers to remove the daughterboard.
      • Before reinserting the daughterboard, make sure all cables that connect to it are out of the way.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus 9 5G answers community for help.
Dominik Schnabelrauch
263,537 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,577 Guides authored
1 Guide Comment
Can i send my mobile at your branch
can you repair
Hassaan - Reply Share
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 88
All Time: 2,797
