Up to 20% off select tools
OnePlus 8 Loudspeaker Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
64
All Time:
1,104
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the loudspeaker in your OnePlus 8.
You'll need replacement adhesive for the rear glass in order to complete this repair.
Note: Retaining water resistance after the repair will depend on how precisely the adhesive is reapplied, but your device will lose its IP (Ingress Protection) rating. However, only the T-Mobile (IN2017) and Verizon (IN2019) models offer IP ratings.
    1. OnePlus 8 Loudspeaker Replacement, Heat the rear glass: step 1, image 1 of 1
      • Power off your phone and unplug any cables.
      • Heat an iOpener and apply it to the rear glass for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
      Ask FixBot
    2. OnePlus 8 Loudspeaker Replacement, Insert an opening pick: step 2, image 1 of 3 OnePlus 8 Loudspeaker Replacement, Insert an opening pick: step 2, image 2 of 3 OnePlus 8 Loudspeaker Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
      • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
      • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. OnePlus 8 Loudspeaker Replacement, Slice the bottom edge adhesive: step 3, image 1 of 3 OnePlus 8 Loudspeaker Replacement, Slice the bottom edge adhesive: step 3, image 2 of 3 OnePlus 8 Loudspeaker Replacement, Slice the bottom edge adhesive: step 3, image 3 of 3
      • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
      • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    4. OnePlus 8 Loudspeaker Replacement: step 4, image 1 of 3 OnePlus 8 Loudspeaker Replacement: step 4, image 2 of 3 OnePlus 8 Loudspeaker Replacement: step 4, image 3 of 3
      • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. OnePlus 8 Loudspeaker Replacement, Slice the left edge adhesive: step 5, image 1 of 3 OnePlus 8 Loudspeaker Replacement, Slice the left edge adhesive: step 5, image 2 of 3 OnePlus 8 Loudspeaker Replacement, Slice the left edge adhesive: step 5, image 3 of 3
      • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
      • Insert a third opening pick under the bottom left corner of the rear glass.
      • Slide the opening pick up the left edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. OnePlus 8 Loudspeaker Replacement, Slice the top edge adhesive: step 6, image 1 of 3 OnePlus 8 Loudspeaker Replacement, Slice the top edge adhesive: step 6, image 2 of 3 OnePlus 8 Loudspeaker Replacement, Slice the top edge adhesive: step 6, image 3 of 3
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    7. OnePlus 8 Loudspeaker Replacement, Slice the right edge adhesive: step 7, image 1 of 3 OnePlus 8 Loudspeaker Replacement, Slice the right edge adhesive: step 7, image 2 of 3 OnePlus 8 Loudspeaker Replacement, Slice the right edge adhesive: step 7, image 3 of 3
      • Insert a fifth opening pick under the top right corner of the rear glass.
      • Slide the opening pick down the right edge to slice the remaining adhesive.
      Ask FixBot
    8. OnePlus 8 Loudspeaker Replacement, Remove the rear glass: step 8, image 1 of 3 OnePlus 8 Loudspeaker Replacement, Remove the rear glass: step 8, image 2 of 3 OnePlus 8 Loudspeaker Replacement, Remove the rear glass: step 8, image 3 of 3
      • Remove the rear glass.
      • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
      • During reassembly:
      • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
      • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
      Ask FixBot
    1. OnePlus 8 Loudspeaker Replacement, Unfasten the motherboard cover: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
      • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. OnePlus 8 Loudspeaker Replacement, Pry up the motherboard cover: step 10, image 1 of 3 OnePlus 8 Loudspeaker Replacement, Pry up the motherboard cover: step 10, image 2 of 3 OnePlus 8 Loudspeaker Replacement, Pry up the motherboard cover: step 10, image 3 of 3
      • The motherboard cover is secured by tight clips.
      • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
      • Twist the spudger to release the clips.
      • Lever the motherboard cover up until you can grip it with your fingers.
      Ask FixBot
    3. OnePlus 8 Loudspeaker Replacement, Remove the motherboard cover: step 11, image 1 of 2 OnePlus 8 Loudspeaker Replacement, Remove the motherboard cover: step 11, image 2 of 2
      • Remove the motherboard cover.
      Ask FixBot
    4. OnePlus 8 Loudspeaker Replacement, Disconnect the battery cable: step 12, image 1 of 2 OnePlus 8 Loudspeaker Replacement, Disconnect the battery cable: step 12, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    1. OnePlus 8 Loudspeaker Replacement, Unfasten the loudspeaker: step 13, image 1 of 1
      Buy
      • A white sticker may coversa screw on the top right corner of the loudspeaker. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
      • Use a Phillips driver to remove the seven 3.3 mm-long screws securing the loudspeaker.
      Ask FixBot
    2. OnePlus 8 Loudspeaker Replacement, Pry up the loudspeaker: step 14, image 1 of 2 OnePlus 8 Loudspeaker Replacement, Pry up the loudspeaker: step 14, image 2 of 2
      • The loudspeaker is secured with plastic clips.
      • Insert an opening pick underneath the center of the loudspeaker's top edge.
      • Pry up to release the clips securing the loudspeaker, levering it up until you can grip it with your fingers.
      Ask FixBot
    3. OnePlus 8 Loudspeaker Replacement, Remove the loudspeaker: step 15, image 1 of 2 OnePlus 8 Loudspeaker Replacement, Remove the loudspeaker: step 15, image 2 of 2
      • Remove the loudspeaker.
      Ask FixBot
Author
with
Manuel Haeussermann
27,784 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 64
All Time: 1,104
