Up to 20% off select tools
OnePlus 7 Pro Battery Cover Replacement
Views: 13K
View statistics:
Past 24 Hours:
9
Past 7 Days:
31
Past 30 Days:
171
All Time:
12,905
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a battery cover on your OnePlus 7 Pro smartphone.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion is decreased.
Be sure to power off the device before beginning the disassembly process.
Follow the iOpener Heating guide for instructions on using the iOpener.
Video Overview
    1. OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: step 1, image 1 of 3 OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: step 1, image 2 of 3 OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: step 1, image 3 of 3
      • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
      • Press gently to eject the SIM tray.
      • Remove the SIM card tray from the device.
      • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
      Ask FixBot
    2. OnePlus 7 Pro Battery Cover Replacement: step 2, image 1 of 2 OnePlus 7 Pro Battery Cover Replacement: step 2, image 2 of 2
      • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
      • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
      • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
      • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
      Ask FixBot
    3. OnePlus 7 Pro Battery Cover Replacement: step 3, image 1 of 3 OnePlus 7 Pro Battery Cover Replacement: step 3, image 2 of 3 OnePlus 7 Pro Battery Cover Replacement: step 3, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
      • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
      Ask FixBot
    4. OnePlus 7 Pro Battery Cover Replacement: step 4, image 1 of 3 OnePlus 7 Pro Battery Cover Replacement: step 4, image 2 of 3 OnePlus 7 Pro Battery Cover Replacement: step 4, image 3 of 3
      • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
      Ask FixBot
    5. OnePlus 7 Pro Battery Cover Replacement: step 5, image 1 of 2 OnePlus 7 Pro Battery Cover Replacement: step 5, image 2 of 2
      • Remove the phone's back cover.
      • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
      Ask FixBot
    6. OnePlus 7 Pro Battery Cover Replacement: step 6, image 1 of 3 OnePlus 7 Pro Battery Cover Replacement: step 6, image 2 of 3 OnePlus 7 Pro Battery Cover Replacement: step 6, image 3 of 3
      Buy
      • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
      • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
      Ask FixBot
    7. OnePlus 7 Pro Battery Cover Replacement: step 7, image 1 of 1
      • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
      Ask FixBot
    8. OnePlus 7 Pro Battery Cover Replacement: step 8, image 1 of 2 OnePlus 7 Pro Battery Cover Replacement: step 8, image 2 of 2
      • Peel off the adhesive cover for the new battery cover.
      Ask FixBot
To reassemble your device, replace the battery cover and follow these instructions in reverse order.
9 other people completed this guide.
Author
with
Selena
3,019 Reputation
14 Guides authored
1 Guide Comment
Could this be used and adapted to replace the charging port?
S. S. - Reply Share
Past 24 Hours: 9
Past 7 Days: 31
Past 30 Days: 171
All Time: 12,905
