Up to 20% off select tools
OnePlus 6T Motherboard Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
107
All Time:
5,914
Comments: 5
5 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 - 45 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show how to replace the motherboard of your OnePlus 6T. Make sure to use the correct tools and to be careful after removing the back cover of the device.
    1. OnePlus 6T Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
      Ask FixBot
    2. OnePlus 6T Motherboard Replacement: step 2, image 1 of 1
      • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
      • Carefully remove the SIM card from its tray.
      Ask FixBot
    3. OnePlus 6T Motherboard Replacement: step 3, image 1 of 1
      • Loosen the binding glue within the phone using a hairdryer or an iOpener.
      • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
      Ask FixBot
    4. OnePlus 6T Motherboard Replacement: step 4, image 1 of 3 OnePlus 6T Motherboard Replacement: step 4, image 2 of 3 OnePlus 6T Motherboard Replacement: step 4, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
      • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
      • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
      • Remove the back cover from the phone.
      • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
      Ask FixBot
    1. OnePlus 6T Motherboard Replacement, Front Camera: step 5, image 1 of 2 OnePlus 6T Motherboard Replacement, Front Camera: step 5, image 2 of 2
      Buy
      • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
      • Use tweezers to remove the battery cover and place it to the side.
      Ask FixBot
    2. OnePlus 6T Motherboard Replacement: step 6, image 1 of 1
      • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
      Ask FixBot
    3. OnePlus 6T Motherboard Replacement: step 7, image 1 of 1
      • Using a spudger, gently remove the midframe and place it to the side.
      Ask FixBot
    4. OnePlus 6T Motherboard Replacement: step 8, image 1 of 1
      • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
      • Remove the front camera from the phone.
      Ask FixBot
    1. OnePlus 6T Motherboard Replacement, Motherboard: step 9, image 1 of 2 OnePlus 6T Motherboard Replacement, Motherboard: step 9, image 2 of 2
      • Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
      Ask FixBot
    2. OnePlus 6T Motherboard Replacement: step 10, image 1 of 1
      • Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
      Ask FixBot
    3. OnePlus 6T Motherboard Replacement: step 11, image 1 of 1
      • Use a spudger to disconnect the signal cables on the right side of the motherboard.
      Ask FixBot
    4. OnePlus 6T Motherboard Replacement: step 12, image 1 of 2 OnePlus 6T Motherboard Replacement: step 12, image 2 of 2
      • Disconnect the slider from the top of the phone with a spudger.
      • The slider is extremely delicate, so it is important you do not attempt to remove it from the sides.
      • Gently pull the motherboard from the left side and remove it from the phone.
      Ask FixBot
7 other people completed this guide.
Author
with
Kristen Gismondi
110,412 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 107
All Time: 5,914
