Up to 20% off select tools
OnePlus 6T Front Camera Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
69
All Time:
2,058
Comments: 5
5 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken or cracked OnePlus 6T Front Camera.
    1. OnePlus 6T Front Camera Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
      Ask FixBot
    2. OnePlus 6T Front Camera Replacement: step 2, image 1 of 1
      • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
      • Carefully remove the SIM card from its tray.
      Ask FixBot
    3. OnePlus 6T Front Camera Replacement: step 3, image 1 of 1
      • Loosen the binding glue within the phone using a hairdryer or an iOpener.
      • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
      Ask FixBot
    4. OnePlus 6T Front Camera Replacement: step 4, image 1 of 3 OnePlus 6T Front Camera Replacement: step 4, image 2 of 3 OnePlus 6T Front Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
      • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
      • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
      • Remove the back cover from the phone.
      • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
      Ask FixBot
    1. OnePlus 6T Front Camera Replacement, Front Camera: step 5, image 1 of 2 OnePlus 6T Front Camera Replacement, Front Camera: step 5, image 2 of 2
      Buy
      • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
      • Use tweezers to remove the battery cover and place it to the side.
      Ask FixBot
    2. OnePlus 6T Front Camera Replacement: step 6, image 1 of 1
      • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
      Ask FixBot
    3. OnePlus 6T Front Camera Replacement: step 7, image 1 of 1
      • Using a spudger, gently remove the midframe and place it to the side.
      Ask FixBot
    4. OnePlus 6T Front Camera Replacement: step 8, image 1 of 1
      • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
      • Remove the front camera from the phone.
      Ask FixBot
2 other people completed this guide.
Author
with
Kristen Gismondi
110,396 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 69
All Time: 2,058
