Up to 20% off select tools
OnePlus 6T Battery Replacement
Views: 60K
View statistics:
Past 24 Hours:
8
Past 7 Days:
72
Past 30 Days:
368
All Time:
59,941
Comments: 23
9 comments on steps, 14 guide comments.
Go to guide comments
Completed: 34
34 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your OnePlus 6T is experiencing battery drainage issues or won’t hold a charge/won’t charge, then it may be time to replace the phone’s battery.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive in order to complete this repair.
    1. OnePlus 6T Battery Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
      Ask FixBot
    2. OnePlus 6T Battery Replacement: step 2, image 1 of 1
      • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
      • Carefully remove the SIM card from its tray.
      Ask FixBot
    3. OnePlus 6T Battery Replacement: step 3, image 1 of 1
      • Loosen the binding glue within the phone using a hairdryer or an iOpener.
      • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
      Ask FixBot
    4. OnePlus 6T Battery Replacement: step 4, image 1 of 3 OnePlus 6T Battery Replacement: step 4, image 2 of 3 OnePlus 6T Battery Replacement: step 4, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
      • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
      • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
      • Remove the back cover from the phone.
      • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
      Ask FixBot
    1. OnePlus 6T Battery Replacement, Battery: step 5, image 1 of 1
      • Remove the single 3mm Phillips #00 screw from the battery.
      Ask FixBot
    2. OnePlus 6T Battery Replacement: step 6, image 1 of 1
      Buy
      • Using tweezers, carefully remove the small metal bracket covering the battery connector.
      Ask FixBot
    3. OnePlus 6T Battery Replacement: step 7, image 1 of 1
      Halberd Spudger
      $2.99
      Buy
      • Using a halberd spudger, gently lift and disconnect the battery connector from the phone.
      • Do not use a metal tool for this step as it may puncture the battery and cause it to leak toxic liquid.
      Ask FixBot
    4. OnePlus 6T Battery Replacement: step 8, image 1 of 2 OnePlus 6T Battery Replacement: step 8, image 2 of 2
      • Grab the red tab on the right hand side and pull until the battery dislodges.
      • It will have some tension as there is tape holding the battery in place. Only remove the battery. Make sure to leave the tape as it will ensure the next battery stays in place.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      Ask FixBot
34 other people completed this guide.
Author
with
Kira D'Agostino
1,775 Reputation
2 Guides authored
14 Guide Comments
Does the adhesive for the back cover need to be replaced? Should I heat the phone and back glass for re-assembly?
Mark Bugajski - Reply Share
Good questions. I think “reassembly is the reverse of these instructions" is a bit simplified. I think the heat is only for removal, but perhaps it would cause the adhesive to rebond after reassembly? Can an ifixit tech comment?
Justin Allen - Reply Share
Just wondering if anyone can clarify the reattachment of the rear panel, as far as whether it is recommended, or necessary, to heat it again, or get a new adhesive gasket. Thanks.
Scott Sparling - Reply Share
Good question! You should replace the back cover adhesive with either a custom-cut adhesive or double-sided tape such as Tesa tape. You can choose to reheat and reuse the existing adhesive, but there may be a chance that the back cover will fall off. If you’re reusing adhesive, be sure to remove any uneven adhesive chunks.
Arthur Shi - Reply Share
What width Tesa tape would work for the replacement of the back cover?
Jamie Wright - Reply Share
Past 24 Hours: 8
Past 7 Days: 72
Past 30 Days: 368
All Time: 59,941
